Question about ignition switch - NewBeetle.org Forums
Old 01-31-2012, 03:36 PM
Default Question about ignition switch
I'm wondering how long does the ignition switch typically last? Mine is '99 AEG with 120k the switch is still fine. However I don't want my wife to be stranded so asking.
BTW, my wife told me that yesterday she parked the car and then she was not able to turn the key. I suppose she got the steering wheel locked and she forgot to turn the wheel a little bit to free the key. However after that her friend helped her by just turned the key and it turned...I'm wondering if this would cause any damage to the ignition switch...
Old 01-31-2012, 04:04 PM
IndyTom's Avatar
Indianapolis, IN, USA
No real set time on how long the iginition switch lasts. I have a 2000 with 170k miles on it and it still works flaylessly. Like your said your wife probably just engaged the steering wheel locking mechanism and that's why she couldn't turn the key. There shouldn't be any damage done to the actual switch by turning the key. I would just instruct her not to panic and to just turn the steering wheel a bit and then turn the iginition key. Just like most cars. If she still has trouble you may have a bad cylinder lock which is different from the actual electronic ignition switch. For now I wouldn't be worried too much and just see if she has any more issues.
Old 01-31-2012, 04:12 PM
Actually when 2 years ago she was driving another car she had this issue and I taught her how to solve it. Now it seems she forgot...
Old 01-31-2012, 04:20 PM
IndyTom's Avatar
And Women tell us we are forgetful Okay, I admit, I forget to take out the trash and do the dishes. It's my selective memory kicking in
Old 01-31-2012, 04:30 PM
That's nothing. Try driving an automatic, forgetting to put the car in park and having the interlock failed so you can take the key out with the car in drive. Then try to start the car and get nothing. Made for a fun evening the first time it happened (hubby's car...him driving ). Still need to take that car into Honda...there's a recall for that.
Old 01-31-2012, 04:32 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
My 98 has 170K+ miles and mine still works fine. My buddy's 99 with over 300K just had his replaced after a valet guy couldn't get it to turn when returning his car. I think that had a lot to do with it! I'm sure it depends on who, how hard, and how many times it's done hard.
Old 01-31-2012, 04:36 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
I have 299k on my '98 and still using the original.
My NB Family...
Old 01-31-2012, 07:43 PM
VWBubba's Avatar
Ljubljana, Slovenia
Car: 2000 2.0 Beetle, Mitsubishi Shogun Elegance 3.2 Tdi, Mitsubishi 2.8td Intercooler.
I worked for many years on roadside recover and Breakdown assist and many times came across faulty ign switches, the main cause ... KEYS !! or too many of them and big stupid key chains.
Keys are alloy and not steel, the interior of the cylinder is mostly brass, both are soft metals. Too much weight on the end of the key will wear it away until it damages the lock or the key will not work.
Take a look at a new and old key, compare the ridges :-)
Steve
Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me, either. Just leave me alone.
Bad Ignition switch? garrett Questions, Issues, Concerns, or Problems with the New Beetle 1 10-01-2011 05:47 AM
ignition switch failure? undertow Questions, Issues, Concerns, or Problems with the New Beetle 0 11-22-2010 06:12 PM
Help Pls - I think my ignition switch is bad Beckweed Questions, Issues, Concerns, or Problems with the New Beetle 4 10-28-2010 02:59 AM
ignition switch chi Technical Modifications 2 05-28-2007 02:41 AM
ignition switch relay ? C89ZX7R Questions, Issues, Concerns, or Problems with the New Beetle 1 12-29-2005 05:58 AM
