1999 vw beetle mass flow sensor? - NewBeetle.org Forums
Old 02-02-2012, 11:07 PM
Default 1999 vw beetle mass flow sensor?
I bought a 99 beetle gls 2.0 engine. The nipple broke apart that connects a black rubber tube from the mass air flow sensor,,do I need a new mass air flow sensor or does the nipple come separate?
Old 02-02-2012, 11:37 PM
This is not the MAF sensor. This is the PCV valve. You can try using some strong glue to make the plastic pieces together and you probably have to use some hot melt glue to ensure the seal. If that doesn't work you have to replace the air intake duct and PCV valve assembly. They are not separable. Take a look at junkyards I'm sure you can find one there.
Old 02-03-2012, 02:14 AM
Supercharged98's Avatar
Fountain Inn, SC, USA
Car: 98 NB S/C'd 2.0L 5 sp
That is the heater for the crankcase vent. It heats up and vaporizes any moisture that comes out of the engine. You have to buy the whole intake tube, since it's glued in. I purchased mine off of eBay for $20. The dealer wants close to $200.
"Deutsche Stahl"
Old 02-03-2012, 10:00 PM
Wow I finally found out what part this is,,,its called a Air Mass Meter hose,,,part # 1c0129684g,,,retails like $271 from vw..
I guess I will try a junkyard or a person parting out a car.
mass air flow sensor pepino68 1.8 Liter Turbo 2 12-23-2010 02:52 AM
Mass Air Flow Sensor fxn351@aol.com 1.9 Liter TDI 6 06-23-2009 07:30 PM
Mass Air Flow Sensor andrzejvan 1.8 Liter Turbo 5 04-05-2009 01:44 AM
mass air flow sensor? bobwb 1.8 Liter Turbo 14 12-17-2007 10:31 PM
FS: 2.0 mass air flow sensor B-Power-B Market Place Archives 1 10-19-2005 09:15 PM
