1999 Beetle code P0322 - NewBeetle.org Forums
Old 02-05-2012, 03:15 PM
Default 1999 Beetle code P0322
My wifes Betty Boop bug has has died twice in the last month. Once while driving second when trying to restart after a 3 minute trip to store. Both times I get a P0322 code. Both times it has restarted after a couple of minutes. My book says check the ENGINE SPEED SENSOR any one know wheres this is located??????
HELP Super Bowl Sunday don't want to be working on this car all day long!!!!!!!
Old 02-05-2012, 03:29 PM
It's located at the front of the engine just behind the engine oil filter. It's an easy replacement and in some way you can get it for as low as $70. But keep in mind to avoid cheap parts. Good luck.
Old 02-05-2012, 03:34 PM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
This DIY; might be helpful:
VWVortex.com - DIY: Crank position sensor - 2.0L
video showing location:
http://www.youtube.com/watch?v=88rNeNunkKo
Old 02-05-2012, 03:47 PM
is it the one that has the long wire harness attached??
Old 02-05-2012, 03:51 PM
crank positioning sensor and engine speed sensor are they the same. Advance auto shows the ESS as a small sensor that a bolt goes thru it to mount
Old 02-05-2012, 03:59 PM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
Speed sensor is VW's official terminology used in the Bentley manuals; crank position sensor generic USA terminology.. afaik, the same thing.
Old 02-05-2012, 04:00 PM
16706/P0322/000802 - Ross-Tech Wiki
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms
Engine shuts off
Engine doesn't start
Speedometer inoperative
Glow Plug Indicator Lamp (K29) flashes
Possible Causes
Engine Speed Sensor (G28) loose
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Engine Speed Sensor (G28)
Special Notes
The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
Yup. Crank and speed sensor seem to be the same, as per Ross-Tech.
Old 02-05-2012, 05:44 PM
IndyTom's Avatar
Indianapolis, IN, USA
Here might be another helpful thread:
VWVortex.com - TECH: MK4 2.0 Crank Position Sensor P0322
Old 02-05-2012, 05:56 PM
IndyTom's Avatar
Does your car have a Manual or Automatic Transmission???
http://www.partsgeek.com/catalog/199...on_sensor.html
1999 2.0L CEL 0171 code S.M.F. 2.0 Liter Gas 2 07-07-2011 05:12 PM
What could cause code P0322 mrathell 2.0 Liter Gas 1 07-26-2010 01:20 PM
Code P0322 and occasional failure to start iFixBethsBug 2.0 Liter Gas 5 04-05-2010 12:50 AM
ABS light 1999 Beetle - no fault code beetlebug7 Questions, Issues, Concerns, or Problems with the New Beetle 1 11-02-2009 12:40 AM
CEL code P0322 rob11g 2.0 Liter Gas 3 04-03-2006 12:48 PM
