New to the 2.0 not new to the wrench lol. So i picked up a 98 2.0 5 speed. HAd a cel light on came back 1&4 misfire and the general misfire. Car runs good over 1500 has a slight mis at idle not bad just a blurb every 10 seconds or so. if i jab the peddle it will misfire a little and stutter. Will stutter over 1/4 throttle till above 1,500 then its just fine. does not seem down on power either.
Kinda figured it need a new coil pack as the codes where linked on 1 and 4 for wasted spark setup. Was wondering if that is the case. I have plugs and wires on the way also. Whats the skinny on plugs and wires intake must come off? Special tools? |
Did you have it scanned for codes? Might shed a bit more light on the misfires.
Those coils do go bad and a set of new plugs is never a bad idea. Make sure they are gapped correctly. It amazes me how many people just assume that the gap is automatically set for their engine. Gap should not be more than .032 That's on my 1.8 but I think it is pretty similar on the 2.0 I don't think you have to take the intake off to get to the plugs. It's a bit tougher to get to than on the 1.8 Turbo motor but it's not impossible. Perhaps a swivel head and socket extension but that is about it. Good Luck and Keep us posted! This link might help! How to : spark plug change on 2001 nb 2.0 As the link shows, check the vacuum lines if you still have those original cloth covered braded lines they $uck and do break easily from age and heat. Replace with more durable silicone tubing or heavy duty rubber tubing. Also don't use E3 Spark Plugs. They are terrible for our Beetles. Just FYI Oh, Welcome to the ORG ![]() Newbie Welcome Kit! Last edited by IndyTom; 02-09-2012 at 03:03 PM.. |
I wouldn't choose the multi-electrode plugs since they suck. Also don't choose platinum ones they suck too. Choose either copper ones or iridium ones. Copper ones have around 50k miles life while iridium ones can easily go beyond 100k.
This is the unit you want. It will diagnose any VW/Audi/Skoda/SEAT etc car out there.
Ross-Tech Store: VCDS License with HEX-USB+CAN Interface |
Hey this CAN interface is not compatible with the '98 model. They use K bus. |
1996-2012 Model cars. K II as well as the newer model Can Bus. There is a model that only covers the K Bus and it's 100 dollars cheaper but he might as well purchase the one that can do both just in case he ever buys a 2006 (or whenever the CAN bus was first introduced) or later VW/Audi/ etc type of vehicle. |
Really? I was told that CAN bus cable doesn't work properly on K bus cars so I bought 2...Seems I wasted my money ![]() But it's fine I bought them on ebay just less than $20.. I'm not quite sure about my memory but I remember I bought the CAN bus cable first and then I tried it on my '99 beetle and it didn't work so I bought the K bus cable. Perhaps this CAN cable is not the same as the one sold on Ross-tech... |
VCDS License with HEX-USB+CAN Interface Works with all diagnostic-capable VW/Audi cars in model years 1990 through the current model year, even the latest models which require a direct CAN connection for diagnostics. That's directly from the Ross-Tech website: Ross-Tech Store: VCDS License with HEX-USB+CAN Interface You get what you pay for. |
You're right but I think it's a very good cheap alternative since the genuine VCDS plus cable cost $350 but mine only cost $110. I can use it to retrive codes, erase codes, do TBA, do READY test, and transmission codes, abs codes and that's all I want. I don't think it's worth spending the other 240 bucks for the genuine product for a home mechanic like me. |
I'm using Windows 7 Ultimate 64bit. No problem at all and I tried both on my Thinkpad X200 and my wife's Thinkpad T400. |
No drivers needed. It recognizes the USB-RS232 port by using windows update. I opened device manager and saw the 2 RS232 ports they are COM3 and COM4. Then in the configuration of VCDS-Lite I select COM3 then test. Make sure that when you hit test the cable has to be connected to the OBD2 port on your car and key is turned to ON.
| Tech. Question, yet again. | Pseudotropheus | Technical Modifications | 3 | 02-21-2010 03:45 AM |
| Ross-Tech VAG COM ? | turbobug | Parts and Accessories | 22 | 09-14-2009 08:50 PM |
| Want-to-Buy Ross-Tech KEY-USB | Duffy | Market Place Archives | 0 | 07-31-2006 04:06 PM |
| Need some Tech . input .. | bugsy98nb | Miscellaneous Hoo-Ha Archive | 3 | 01-13-2006 03:27 PM |
| Tech Question | BlackBug | 2.0 Liter Gas | 3 | 12-27-2005 12:43 AM |
