I read somewhere in here that someone had all the same symptoms and it turned out to be the rear lid motor was shorting out and blowing a fuse the windows and locks also used. I can tackle the motor later this week and use a key until then but I was hoping to find the fuse for my windows today. I will check the ignition switch too. Thanks for the tip.
D2 thanks for the tip once again but I have the fix and it was the easiest thing ever. I searched and searched to make sure I was checking all the relative fuses and relays. Never did figure out which fuse on the relay panel goes to the windows buttt... I decided to disconnect the negative battery terminal to see if there was a relay that would reset. waited a few minutes and reconnected the battery. Presto everything is working again. mind you I have also disconnect the rear lid motor as i hear that shorts out causing this problem so It will be getting checked out next. Oh the sweet victory!
| Need help finding... | kelleygraves2 | Miscellaneous Hoo-Ha | 10 | 10-02-2011 08:52 PM |
| OK, not really finding this problem | pikagirl | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 06-26-2011 06:06 PM |
| Link fuse failure in engine bay fuse box | Stlbug | 2.0 Liter Gas | 3 | 06-05-2011 10:44 PM |
| Finding out car sat for a while... | New2BeetleLuv | 2.0 Liter Gas | 10 | 02-10-2011 02:15 AM |
| fuse 34 10amp, Engine Control Elements, FUSE BLOWS | frankgant | 1.9 Liter TDI | 1 | 10-21-2009 04:57 PM |
