I don't have a bug, but it is a 01 Jetta 2.0. I came to this sight, because you people seem to know what your talking about then most Jetta sights!Anyways here it is- 01 2.0 gas GLS jetta was driving the other day and the temp light came on and started to blink, so I looked at the gauge and it was pinned to red. I also have no heat! Popped the hood looked like everything was good with no overheating steam or any signs of overheating. I changed the thermostat and check the old one anyway and it was still good. Started it up and it won't come on until I drive it about 5 min, but it still happens. I looked for leaks and felt the hoses for temp and pressure, but everything looked good. The coolant level was at the min level the first time this happened and I did add the dexcool to it, because that will mix good with the G12 or whatever the pink stuff is. Fuses check,coolant check,hoses check,leaks check, thermostat check. Any ideas on what this could be? Heater core? Waterpump?Temp sensor? I can't even seem to locate the waterpump on this car. Really anything would help!! Thanks |
VW has it stuck in a housing at the outlet of the waterpump, and the entry to the block??? Why, I Asked, and they couldn't give me an answer that made any sense to me! Also, '98 on 2.0 motors are noted for bad waterpumps!(plastic impellers seem to disintergrate over time and plug things up) Good luck, and get a service manual if it's out of warentee! Earl
75 year old car nut
That was how my '99 was when the impeller on the waterpump shredded at 45k miles...there was simply no flow of te heated coolant, and therefore no heat, and the thing was giving me the "overheating" signal. It was an expensive repair, did the timing belt at the same time, because they are all in the same vicinity.
Time is the Beauty of the Road being Long -- Blues Traveler |
My beetle now has over 82,000 mi. on it, and have had the timing belt changed at 60,000, and the serpentine at 80,000,(did it myself, after the stealer quoted me $165.00 to do it! By the way, a tool can be made out of a length of 3/4" square tubing,(you choose the length) of about 12-18" the end fits over the 1/2"X3/4" protrusion on the tensioner. and use a hardend pin of the right size to hold the tensioner while replacing the belt! It took me less than 1/2 hr to do, and that included making the bar!!! $165.00 HaHa Earl |
I'd be leaning towards a bad waterpump, rather than the temp sensor, especially since you say you're getting no heat. Your coolant level is correct? If you can get the thermostat out again (and if the Jetta 2.0 is the same as the Beetle) you can reach your fingers in the thermostat hole and to the left and feel the waterpump impeller. If it's broken, you'll know it.
You may want to pop off that cover that houses those three large green fuses located inside the small compartment located directly atop the battery. If I'm not mistaken, the fuse on the far left governs the Engine Coolant Temperature Sensor. Check to see if that baby is blown. Could be a VERY cheap fix...
All (he is) saying...is give (war) a chance... [apologies to John Lennon] "Nibblin' on spongecake, watchin' the sun bake, all of those tourists covered in oil..." "Your Freudian slip is showing..." "Reality is just that surreal time between my dreams" - me |
Currently I am having the same problem. I have a 03' Beetle and the red temp. light just came on yesterday when it was 50 degress outside and the car was just started up. So I know it was not over-heating. I also tried to get it to heat up today, then I checked it with a temp. gun and it was steady 200-204.
It is still under warranty so I will take it in today and see what they have to say. Also what specific sensor controls the light? Thanks. . . . . . . . . |
Yep do a search for green temp sensor and will get a ton of threads discussing the false overheating light. Very cheap and easy fix.
| Big Problem! | BlackBug | 2.0 Liter Gas | 4 | 02-15-2006 07:25 PM |
| What could be the problem? | CyberGrnBug01 | 1.8 Liter Turbo | 2 | 02-08-2006 11:09 AM |
| 2000 Beetle overheating??????? HELP | stevebug | Questions, Issues, Concerns, or Problems with the New Beetle | 12 | 01-16-2006 10:30 PM |
| Temp light & Overheating | Oddball | 2.0 Liter Gas | 2 | 11-16-2005 04:43 PM |
| Problem! Need some help. | kg4fku | 2.0 Liter Gas | 9 | 10-10-2005 01:19 PM |
