Sensors/Codes/Lights Headache - NewBeetle.org Forums
Old 04-16-2012, 08:55 PM
Default Sensors/Codes/Lights Headache
Hi guys!!
I started my new thread here:
New Bug, New Questions!
but right now I'm focused on the following problems I want to fix. The check engine light is on w/ these codes:
P0103
Mass or Volume Air Flow A Circuit High Input
P0202
Injector Circuit / Open - Cylinder
P0135
o2 Sensor Heater Bank 1 Sensor 1
2 days prior to the engine light coming back on, I had it on and cleaned the sensor w/ MAF cleaner from advance auto parts and replaced the air filter. Yesterday, the light came back on. While I was checking the hood, I noticed there's a hose/tube right below the MAF sensor that came off, and needs a clamp or something to be tight... could that be causing any of this?
Thanks in advance, any input is much appreciated!!
Homelink=headache! kelleygraves2 Questions, Issues, Concerns, or Problems with the New Beetle 6 06-21-2011 10:51 AM
Headlight Headache... sntaylor2005 Technical Modifications 12 02-15-2011 08:43 PM
P 1198 headache Limitwheel 1.8 Liter Turbo 1 07-24-2010 08:07 PM
help! itercooler headache eliramos525 1.8 Liter Turbo 3 02-06-2010 09:30 PM
a/c problem, headache ???? mickstir 2.0 Liter Gas 0 06-28-2008 07:03 AM
