P2181 and normal coolant temperature reading - NewBeetle.org Forums
Old 05-23-2012, 05:30 PM
Default P2181 and normal coolant temperature reading
Hello,
My 04 beetle (2.0 L) threw a P2181 code in Sep. 2011. I had the code cleared and read related threads in this forum. It's been quiet since then until this May. The same code showed up again. I cleared it and it came back after 2 days with the same code.
Today I checked the coolant temperature on a local drive. It started normal and then increased to about 170F. It stayed at 170F for about 5 min and then increase to about 200F. It fluctuated from 195 to 210F afterwards. The check engine light was not on during this 1-hr drive.
I was wondering if someone could comment on this observation. I am not sure if this is normal. I do have the notorious black coolant temperature sensor, and plan to switch to the green one. Still I am a little hesitant without collecting more input.
Thank you all in advance for any help or suggestions.
PS. My wife is also complaining about slow idling. I just had the oil changed and all fluid levels checked, so no clue what to do next.
Old 05-23-2012, 11:09 PM
Garage
Change the sensor first. Then worry about values later. Though the numbers sound about right, maybe a bit high, but the temps would probably drop due to the fans kicking on.
Old 05-24-2012, 06:07 AM
Thanks for the reply. What do you think of the fluctuation? I got a Tiguan last year and noticed that the coolant temperature stays at 190F after warming up and is very very stable. I don't know if new beetle uses a similar mechanism to control the temperature, but the fluctuation observed on my new beetle seems odd in comparison with the Tiguan.
Old 05-24-2012, 02:05 PM
Garage
I don't think you're going to see the temp gauge move on new cars very much. I'm sure the temp does fluctuate (the fans will come on when it gets to a certain temp and then shut off after its cooled) and we can see that in our old '84 Jetta. But these new temp gauges aren't really the best gauges from what I understand. They are good enough to know if you aren't getting warm enough or overheating, but they aren't really going to fluctuate. I've not seen any car of ours that is '00 or newer that really fluctuates the gauge. But the temp will change a bit.
Old 05-24-2012, 10:22 PM
That's very good to learn. Thank you!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Coolant Temperature Sensor....gone bad? orangeshrimp72 1.8 Liter Turbo 9 09-29-2010 02:04 AM
what is normal coolant temp for a 2.0 fuelman 2.0 Liter Gas 6 07-16-2010 04:57 AM
Normal Guage Reading for Oil and Temp Scorpius 2.0 Liter Gas 1 10-18-2009 05:22 PM
What is 'normal' operating coolant temperature? dblvsn 1.9 Liter TDI 5 02-26-2008 09:34 PM
which coolant temperature sensor? strorg 2.0 Liter Gas 4 10-31-2007 12:02 PM
