Odd cooling problem - NewBeetle.org Forums
Old 02-27-2006, 03:17 PM
SPIRU's Avatar
RESPECT MY AUTHORITAH!
Naples, FL, USA
Car: Black Rain - 2K1.5 Black GL
Exclamation Odd cooling problem
Ok, I'm having a slightly different cooling problem then some of the other related threads, so hence the new thread . Yesterday while driving to work my temp gauge started flashing red, then when I got into the driveway my speed decreased below 20 MPH and the red light went off, I checked under the hood as soon as I got parked and noticed antifreeze coming somewhere near the right side below the coolant reservoir. Did it again today, (tho no leaking anywhere) and as soon as I slowed my speeds down the red light went off again. All the hoses look fine and I have heat, so anyone have any ideas?
Tríd an bpian a bheirtear solas nua!
Most of us spend our lives as if we had another one in the bank - Ben Irwin
Live Strong / Black Rain my NB! / Love Da Scot / My flickr / My Tattoo / MySpace / My XBL GamerTag
Old 02-27-2006, 03:50 PM
Billsbug's Avatar
Get in.Buckle Up.Hang on.
USA
Sounds like what I just went thru: water pump.
wolfsbürgwe.:Rks
Originally Posted by gilligan
Old 02-28-2006, 01:40 AM
rcyRegistered Member rcy is offline
Save a horse, ride a....
Burlington, Ontario, Canada
Car: 2000 GLS, silver arrow
Water pump, and unless you want to spend a whole lot more cash, don't drive the car with the red light flashing. This is telling you that it's overheating. Continue to drive and you'll need a lot more than a water pump - head gasket, warped head, overheated tranny etc etc.
While you or your mechanic are in there, I'd recommend doing the timing belt, thermostat and serpentine belt. The two belts have to come off anyway, and since the expensive G12 is out of the car, you might as well do the thermostat too.
Also, look for an aftermarket pump with a metal impeller. The OE pump has a plastic impeller and they tend to fail at an alarming rate.
Old 02-28-2006, 01:49 AM
Bugmonkey's Avatar
Tell your mom I said hi
TX, USA
Car: Grey GLS TDI
Yeah..What he said.
Park it 'til you can fix it. Otherwise it can go from bad to worse real quick.
Your car may be faster. But not by much, and I'll catch up when you have to stop for gas.
Old 02-28-2006, 01:14 PM
SPIRU's Avatar
Naples, FL, USA
Thanks guys, now didn't one of the VW venders have a kit for around $200 that came with a metal impeller?
Old 02-28-2006, 01:33 PM
Billsbug's Avatar
USA
DOH! Where were you last week when I needed you (just had new pump installed under warranty)?!
Old 02-28-2006, 02:49 PM
Sorry...but if it was under warranty (dealer??), they wouldn't have put a metal one in anyway. I've heard from my VW parts guy that the water pump has been slightly redesigned (if it's like the brake switch redesign I wouldn't get my hopes too high). Apparently some spring that had been outside the pump body (between the pump and impeller) has been moved to inside the pump body. Whether this will help with the plastic impeller breaking is debatable.
Old 02-28-2006, 03:00 PM
Billsbug's Avatar
USA
Yeah, one of the dealer mechanics told me that the impeller sometimes moves to a forward (I think) position and then gets stuck against the housing, so it can't turn, thus causing the overheating issues, maybe exactly what u r talking about..
Old 03-01-2006, 12:33 AM
Sunbury , PA, USA
I have the water pumps with the metal impeller.
http://www.metalmanparts.com/display...&categoryId=36
I also have a timing belt kit with the same pump.
For parts, repair and timing belt tool rental www.metalmanparts.com
Old 03-01-2006, 05:19 AM
SPIRU's Avatar
Naples, FL, USA
Do you take any other form of payment? I was ready to order the kit but didn't see any options other then paypal.
Edit: Sorry Metal Man, your price was best but I need these parts ASAP. I ordered the ECS Ultimate Timing Belt Kit ES#2238. Now anyone done the job themselfs? I'm thinking of doing just that but would like some input from you guys.
Old 03-01-2006, 06:32 AM
Kevmo's Avatar
V-Dub lover since 1968
Sonoma, CA, USA
Car: Red 1999 GLS
Smile
Hello all,
My only question regards the fact that Spiru stated that he still has heat. This seems puzzling in light of the fact that the water pump has to be functional in order for you to get hot water to circulate throughthe heater core. It seems possible that this could be a problem with the cooling fans not running.
My 99 has recently manifested similar symptoms on a couple of occasions, but only when the car is at idle and sitting still. I can drive at highway speed all day with out any overheating problem, and I know that my fans are not running, but my heater works just fine and helps cool the engine down if the over-temp light comes on. I think you should investigate the cooling fans before the expense of a new water pump Spiru.
Good Luck,
kevmo
Kevmo-n-Lil'Red
Old 03-01-2006, 06:45 AM
SPIRU's Avatar
Naples, FL, USA
Originally Posted by Kevmo
Hello all,
Good Luck,
kevmo
Thanks for the input, but the fans work. Just hope the kit does the trick but time will tell..
Old 03-01-2006, 01:54 PM
Billsbug's Avatar
USA
Wow, what a great price! Future mod fer sure dood...
Old 03-01-2006, 02:07 PM
It's a bit late now, since you've bought the parts, but if you take the thermostat out, you can reach your fingers in and to the left of the opening and feel your waterpump. If the impeller has broken or is freewheeling, you'll know it.
Old 03-02-2006, 01:23 AM
Sunbury , PA, USA
Sorry , at this time just paypal or a money order if you're not in a hurry.
Recurring code P2181, Cooling System Performance jhs914 2.0 Liter Gas 68 12-11-2011 05:22 PM
Engine Cooling Problems TxRedBeetle 2.0 Liter Gas 7 03-15-2006 06:31 AM
cooling fan help iceman Technical Modifications 6 01-23-2006 10:45 PM
Cooling Fan Problem takarick 2.0 Liter Gas 5 01-12-2006 04:15 PM
Cooling Fan Not Comin On... supercharged_v6 2.0 Liter Gas 20 01-03-2006 05:21 PM
