Bought my daughter a 1998 Beetle 2.0 Automatic. I took her driving this weekend to get her ready for her road test. We stopped for lunch over a hour from home. When we got into the Beetle to leave I turned the car over. it made one single click and then nothing. all the lights dimmed while it was turning over but nothing happened. I immediately thought "Dead battery" after all the battery is 5 years old. So the closest parts store was a 45 minute walk one way. After buying the correct battery and tools. we walked 45 minutes back to the car replaced the battery only to come up with the same outcome. one click and then nothing.I tapped the starter with no luck. Its not verified yet but the man we bought the car from said when we bought it the starter was replaced a month before he decided to sell it. I am going to remove and test the starter this week, If it turns out to be good, does anyone have any other ideas?
You need to pull the switch out; in some instances the wire harness to the switch connector overheats causing wire casings to split and the bare wires to fray and touch. This step in the Blend Door DIY shows you how to remove steering column covers.
Pulled the column apart and found no bad wires or any burnt wires. Next step was the starter. removed the battery and tray. Found the wire with pigtail not connected to the solenoid.Also found the wire to be frayed and showing. Repaired the wire and reconnected the pigtail to the solenoid. All I got was a click when I turned the key. So next step was to have the starter tested. Pulled the starter and headed to Autozone. They hooked the starter up it went 3...2.....1..test, Instant fail.The starter motor would not even turn. So now I ordered a new replacement starter online and should be good to go once it arrives.
UPDATE: Replaced the starter. Found the Power wire going to the solenoid exposed and shorting. Also the plug to the starter broken. Replaced/Fixed both these issues along with a new starter and Battery. Car has great power starts fine and actually runs smoother.
NEW ISSUE. I bought a new N80 valve I will be installing tonight. Because of the fueling and starting issues. I scanned the car today at lunch and found the Following codes. PO319 PO422 PO440 PO442 My new problem is if I shut the car off after a trip. and try to start it within 40 minutes of shutting it off it just cranks and does not fire. If I let it sit awhile and come back it starts right up. This is not a good fix when my boss is expection me to uphold a 1 hour lunch!!!!! any ideas? |
| HELP! Stranded - Red Temperature Light | HopeARK | 1.8 Liter Turbo | 27 | 07-30-2009 06:33 AM |
| Oil filter stuck< stranded vert bug! 2.0 | 58and03beetles | 2.0 Liter Gas | 11 | 04-10-2009 02:32 PM |
| '05 Stranded in ATL | trunk3d | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 09-23-2008 01:48 PM |
| Four DTC's Beetle will not drive. Stranded | TexasBeetle | 1.8 Liter Turbo | 4 | 05-28-2008 05:48 PM |
| Beetle has left home again :( | Susie F. | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 10-30-2007 05:09 PM |
