2005 beetle engine suddenly goes off - NewBeetle.org Forums
Old 11-27-2012, 05:25 AM
Question 2005 beetle engine suddenly goes off
Hi there. I just got a 2005 beetle a few weeks ago and its been great so far. Only this morning while at the traffic lights, the engine suddenly went off.... :S .... I then managed to start it up fine. Im just wondering what that was all about. I didnt notice any warning lights before this happened and none appeared after. Any idea what could be the problem?
This is an auto btw...
Old 11-27-2012, 01:32 PM
OH, USA
Car: 2005 Cabrio GL
I'd have it scanned for error codes. Most auto parts stores will do this for free, but the codes you get from them will be generic OBD-II codes. A VW mechanic ought to be able to get more specific codes using a VAG specific scanner.
Old 11-27-2012, 02:58 PM
Knoxville, TN,
Just a heads up.... if the Crank Speed Sensor (G28) goes off line, the engine will die. If it goes back online before you try to restart the car, then there will not be any fault codes.
I've shown people on my car where I kill the engine by unplugging the G28, then plug it back up and restart the engine, no codes.
If the car is at speed (driving down the road), and the G28 goes off line, then it might feel like a misfire or a stutter, but again, no fault codes.
I'm not saying the G28 is bad on your car... lets see if you have any fault codes because for all I know you have 10 Short to Plus codes... something that a generic OBDII scanner might not pick up on.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 11-27-2012, 03:26 PM
IndyTom's Avatar
Indianapolis, IN, USA
My money is on the Crankshaft Positioning sensor/also known as the RPM Impulse sensor or engine speed sensor. That is the only item I can think of that would stall the car out like you described.
Not difficult to swap out if it is a manual transmission. Little harder if you have an Automatic.
Volkswagen New Beetle 2.0 > Search > Crankshaft > ES#252763 Crankshaft Position Sensor - 06A906433C
http://www.youtube.com/watch?v=evqBim8G9g4
Tags
engine goes off , new beetle 2005
2000 Beetle Suddenly Won't Start new_beetle_lover 2.0 Liter Gas 5 09-25-2010 08:05 PM
2005 Bettle just bought from used car lot. Engine light + More. NEED HELP! bettlenewbie 2.0 Liter Gas 10 05-27-2010 08:59 PM
Swap 2005 5-cyl new beetle engine and trans to 2000 with a 1.8 Turbo? WW2 Engine Swaps 8 03-31-2010 11:28 PM
WTB 2005 Beetle under engine skidplate eldo7709 Parts and Accessories 1 11-11-2007 03:38 PM
HELP : ATF changed - Check Engine Light suddenly on ptmlinh Transmission Talk 3 08-20-2006 01:38 AM
