98 2.0 problems - NewBeetle.org Forums
Old 12-10-2012, 12:19 AM
Salt Lake City, Utah, USA
Car: 98 Beetle 2.0
Default 98 2.0 problems
I have scoured the forum looking for information on my Beetle that I just got. I got it pretty cheap because there was some problems with it.
I am getting 5 codes. All codes were there before I bought the car.
1. P0510
2. P0117
3. P0121
4. P0341
5. P1544
I am currently working on the p0341 code.
Since I bought it I have replaced the timing belt, water pump, and tensioner and verified that all the timing marks line up perfectly. So I start doing voltage checks and when testing wires 1 and 3 on the cam sensor connector I am only getting 1.98v.
I am unable to find any further diagnosis on this problem. If anyone has any info that can help me it would be greatly appreciated.
Old 12-10-2012, 12:33 AM
IndyTom's Avatar
Indianapolis, IN, USA
Could be your Camshaft Sensor G40 is bad:
16725/P0341/000833 - Ross-Tech Wiki
16725/P0341/000833 - Camshaft Position Sensor (G40): Implausible Signal
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Wiring from/to Camshaft Position Sensor (G40) faulty
Timing misaligned
Possible Solutions
Check Wiring from/to Camshaft Position Sensor (G40)
Check Camshaft Position Sensor (G40)
Check Timing
Old 12-10-2012, 12:37 AM
IndyTom's Avatar
Code P0510,P0121 and P1544 are related to the throttle body. Find someone in your area with a VAG com and have them do a Throttle body adaption on it. That should take care of it.
Old 12-10-2012, 12:41 AM
IndyTom's Avatar
P0117 is your Coolant Temp Sensor. 5 minute fix and you should be good to go.
Old 12-10-2012, 12:50 AM
Car: 98 Beetle 2.0
Is there a wiring diagram for the cam circuit somewhere? With me getting only 1.98v to the cam sensor I am thinking that it is either bad wiring or bad ecm. I am not sure which pin on the ecm connector to test for high resistance.
As far as the vagcom I am looking for someone that has one but am so far unsuccessful. If anyone here is in SALT LAKE and has one that would be awesome.
I REALLY HOPE THAT IT IS NOT A BAD ECU!!!!!!!!!!!!!
Old 12-10-2012, 01:29 AM
Bratgirl's Avatar
Beetle gone bye bye.
Riverton, UT, USA
Car: Currently Beetle-less :(
You could call Utah Imports. They specialize in VW's and I know they can do a throttle body adaptation for you. Not syre how much it would be, but they are great people and easy to work with.
Live a Life of Serenity, Not a Life of Regret.
Currently Beetle-less...
Previous NB 2002 GLS Double Yellow "Pixie"
Previous NB 2000 GLX Black "Little Ed"
2010 Dodge Challenger Bright White "Baby"
2013 Dodge Dart Header Orange "Nemo"
Old 12-10-2012, 01:31 AM
Car: 98 Beetle 2.0
I will give them a try as well as Streamline Industries. Hopefully I can get it fixed tomorrow.
Still having A/C problems tklagesse67 Questions, Issues, Concerns, or Problems with the New Beetle 20 07-29-2011 09:27 PM
NB problems dpmeeks Questions, Issues, Concerns, or Problems with the New Beetle 4 08-24-2009 04:08 PM
Little problems that add up to BIG problems, all electrical/light associated. mrsBos Questions, Issues, Concerns, or Problems with the New Beetle 3 10-25-2008 10:31 PM
A/C Problems!!??? jbthompson Questions, Issues, Concerns, or Problems with the New Beetle 6 08-20-2008 09:55 PM
Uh Oh! Problems i've run into BeetleCouture Paint and Body 17 07-08-2006 10:40 PM
