Rebuilt Engin in a 2.0 VW Bug - NewBeetle.org Forums
Old 01-02-2013, 04:56 PM
Husker Fan Jim
Omaha, NE,
Car: 1999 VW New Beetle
Default Rebuilt Engin in a 2.0 VW Bug
My 1999, 2.0L Gas Engine "died' about a month ago. My daughter was driving it and the Oil Cooler Gasket blew a hole so big, all the oil blew out of the engine. She drove it for several miles with no oil in the engine. As a result the Main Bearings are all torn up. I am planing on putting in a rebuilt engine in it at some point but here is my main question.
The transmission I have in it now is an automatic. I hate it because I prefer a manual. Not only that, the gears are starting to slip. If I buy a rebuilt engine, Can I put a Manual Transmission on the new engine before it gets put in the Bug? If I can, do I have to "knock out holes" or modify the chassis to install a clutch pedal and a shifter?
Thank you
Locutus 28
Old 01-05-2013, 09:38 AM
Default Hyrbrid
While you're at it, why not turn it into a hybrid beetle?
Old 01-05-2013, 04:43 PM
Fond Du Lac, Wisconsin, USA
Car: 2000 Beetle GL
Search first as I have seen a few posts about this. Otherwise I would ask IndyTom or TheCheat. They seem to be the goto guys around here.
You will ned a few things like the pedals, shift cables, shiftier assembly, etc
Old 01-05-2013, 05:23 PM
Certainly do-able. And if you were doing a manual swap, engine out of the car makes everything much easier. That's how we did the swap on our TDI. But that's a bit easier since you don't need a new ECU.
rebuilt engine? stephany Questions, Issues, Concerns, or Problems with the New Beetle 2 07-21-2012 09:15 PM
Rebuilt Engine BlueMoon New Member Forum 8 10-28-2008 11:04 AM
Rebuilt/Salvage Title jbthompson Questions, Issues, Concerns, or Problems with the New Beetle 20 10-26-2007 10:31 PM
Butter in Engin oil refill cap llq007 Questions, Issues, Concerns, or Problems with the New Beetle 5 02-11-2007 04:11 PM
Wb Tdi Engin Cover ETBUG Market Place Archives 5 02-22-2006 05:14 PM
