Upsolute Chip - NewBeetle.org Forums
Old 03-09-2006, 05:26 AM
Default Upsolute Chip
Have you been satisfied with the upsolute chip in your 2.0? Please let me know your experience. All feedback is wellcome. I have a 2004 GLS 2.0 and I am looking for more torque and better throttle response. Thanks!
Old 05-08-2006, 03:38 AM
weldtech's Avatar
Pressure makes diamonds
Missouri, USA
Car: 2002 Black GLS 5 speed 2.GO
I was going to ask the same exact thing...
Old 05-08-2006, 04:05 AM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
There's also Rocketchip and GIAC. People say upsolute is the best for comfort driving, and people say GIAC is the most extreme.
If you want something a bit more, i'd reccomend getting a small techtonics cam, an exhaust, or an intake.
A urethane dongbone mount insert would give you more feel of hte engine and better shift feel.
Old 05-08-2006, 02:12 PM
heyou's Avatar
Gaithersburg, MD, USA
Car: 2000 Cyber Green GLS, 2.0L
Would this stop my engine from rocking so much at idle? I can see it visibly shaking with the hood up, and I'm almost positive that it's responsible for causing a clacking sound from the engine.
Old 05-08-2006, 03:57 PM
Toad's Avatar
Mableton, GA, USA
yup, the engine will rock less with less felxible mount.
Old 05-08-2006, 04:05 PM
heyou's Avatar
Now the $1,000,000 question: Can I do this myself?
Old 05-08-2006, 04:22 PM
weldtech's Avatar
Missouri, USA
That was the (next) exact thing I was going to ask...
Old 05-08-2006, 04:37 PM
jpdeuce's Avatar
Diesel Inside
Frisco, TX, USA
Car: 06 Jetta TDI
If it's anything like the TDI...the "chip" can mean different things. Sometimes it means reprogramming your computer...in which case you can uninstall the computer, send it to the chip programmer, then reinstall. Yes you can uninstall and reinstall. But the car will be down while it is getting programmed. For the TDI it's not a part you buy and then plug in to the car...but it may be different for the gasser.
Upsolute usually has vendors you can take your car to, leave for a day, and then pick up completed. I believe this is what I have read. Other chip tuners may not have someone in your area so you have to remove the computer and send it to them.
Old 05-08-2006, 04:53 PM
heyou's Avatar
I was referring to the dogbone mount.
Old 05-08-2006, 05:41 PM
Toad's Avatar
Mableton, GA, USA
It's do-able, I didn't do mine myself. All i hear you gotta do is have the front of the car raised up, and use a car jack to hold the engine up while hte mount is removed.
Old 05-08-2006, 06:21 PM
heyou's Avatar
Found this for all those interested in the dogbone mount:
http://forums.vwvortex.com/zerothread?id=1588015
It was done on a 99' Jetta, with a 2.0AEG engine, so it should be almost the same for us!
Chip Tuning.. BlackBug 2.0 Liter Gas 30 07-30-2009 05:01 AM
What NEEDS to be done with a new chip to up the boost? BoostedOne 1.8 Liter Turbo 5 02-18-2006 06:38 PM
APR Chip SIX SPEED 1.8 Liter Turbo 33 02-15-2006 04:08 AM
Chip.. NB18T 1.8 Liter Turbo 2 11-23-2005 09:44 PM
chip heezabadboy Technical Modifications 3 11-18-2005 05:01 PM
