NB Headlamp replacement - NewBeetle.org Forums
Old 03-25-2006, 07:26 PM
Default NB Headlamp replacement
OK, to replace the headlamp on the NB does the replacement part have to be an authorized VW replacement part? Or, will any garden variety replacement part from your friendly neighborhood auto parts store do?
Old 03-25-2006, 07:36 PM
warren's Avatar
ToD Maiden Voyager
Yorktown, VA, USA
Car: Chili Beanie a Tornado Red B12, Ikiane, a 2001 Techno Blue NB, & Marilyn, a 1979 Triple White 'Vert
no need to go to the dealer...wal-mart or local auto parts store is your best (and less expensive) route to take.
Warren
"And I think it's gonna be alright. Yeah, the worst is over now, the mornin' sun is shinin' like a red rubber ball."
1966, Paul Simon & Bruce Woodley.
Old 07-20-2006, 07:52 PM
Default 01 Beetle Headlamp help !!
If you break the ring trying to get it loose and replace the bulb, are you screwed ??
Old 07-20-2006, 10:59 PM
Bugmonkey's Avatar
Tell your mom I said hi
TX, USA
Car: Grey GLS TDI
No.
Counting upgraded bulbs I've had the head lights out of two different NB's 6 times. I broke the little crosshatched designed depressy thingy 5 of those times. It seems nearly any amount of pressure breaks them.
If you break the part you push up on then the whole thing needs to be replaced in order to get the light to lock in place.
Part numbers are:
1CO-806-629-A
1CO-806-630
$10.70 a piece from 1stvwparts.com
3 screws replace them.
One of the best investments I have made for removing head and tail lights has been a large suction cup like body repair dudes use. Stick it to the light and pull. Use only gentle pressure because you can separate the lens from the light body if you pull to hard.
Your car may be faster. But not by much, and I'll catch up when you have to stop for gas.
Headlamp rubber seal said goodbye AZBug Questions, Issues, Concerns, or Problems with the New Beetle 1 03-07-2006 05:28 PM
VOLKSWAGEN TURBO BEETLE Head light Headlamp hdtv 1.8 Liter Turbo 6 02-21-2006 06:51 AM
Replacing my headlamp story... ;-) Jerry7171 Miscellaneous Hoo-Ha Archive 7 12-11-2005 01:41 AM
Headlamp bulb Part Number for '01 1.8T New Beetle racerdeb Market Place Archives 1 12-04-2005 05:43 PM
FS: HID for New Beetle - incl Headlamp assembly ksanchez Market Place Archives 8 11-02-2005 08:47 PM
