Bump.
Due to the emergence of another thread, I've learned that the wires are probably not the problem It's the Platinum 4's I have in there. Damn it. NGK's it is. But I still want info on how to install these wires. |
Well, since you are replacing the wires, you can just yank the old ones off the plugs. If you were just doing plugs and re-using the wires, you'd have to be VERY carefully removing the wires because they damage very easily.
The only tricky thing is the ignition coil side of the wire. Notice when you get the new ones, there is this little compression ring. When you put them on, the ring compresses and there is a groove in the coil where that ring expands and locks the connector in. These are a biscuit to remove. I don't know of any trick (if someone does - please, let me know!) except to pry them off and say a prayer that you don't crack the ignition coil.
"The rich ruleth over the poor, and the borrower is servant to the lender." Proverbs 22:7
Got the wires in, went out and got the NGK plugs, and now everything is working like it should.
Installation was a breeze. I just took close care to make sure the new wire was the same as the old wire. Same cylinders and such. The only thing that I had to do otherwise was take off (what the Bentley manual calls) the secondary air pump. Easy take off, easy put back on. Success! |
| 06 bumper plug | 06Babe | Paint and Body | 7 | 03-11-2006 10:10 PM |
| Spark Plug Wires? | jesse | 1.8 Liter Turbo | 7 | 03-06-2006 08:20 PM |
| Trailer light plug? How to attach wires? | Love Machine | Technical Modifications | 2 | 02-13-2006 08:07 PM |
| Spark wires - Do I need to remove the manifold? | [lot] | 2.0 Liter Gas | 17 | 11-21-2005 05:51 PM |
| Problems changing plug wires & fuel filter. | jent | 2.0 Liter Gas | 8 | 10-10-2005 08:04 PM |
