Say, I noticed a little "tick-tick-ticking" at idle yesterday, that I've never noticed before. Sounded like what I remember usually being called a "loose and/or noisy tappet." What you any of you out there with the 2.0 think it might be (due to)?
My 2003 platinum grey Turbo S. |
I think it´s related with fuel re-circulating. It could be magnetic valve for coal-filter or there is fuel re-circulating valve wich makes noise at idlespeed.
These are my wild guesses! Hydraulic liters are very simple to check. Ok, you have to take valvecover and inletmanifold out first! Test lifters by pushing them downward with a suitable wooden dowel with camshaft lobe pointing up. If lifter can be pushed downward more than .004" (.10 mm), replace lifters. Lifters must be replaced as a set. Last edited by Tetsa; 04-14-2006 at 07:23 PM.. |
There were two versions of that checking, so keep it between 0,1-0,2mm
- Push hydraulic lifter down lightly with a wooden or plastic wedge. If when pushed down a 0.2 mm thick feeler gauge can be pushed between the camshaft and lifter, replace that lifter. Note: Do NOT start the engine for approx. 30 minutes after installing new lifters. Hydraulic compensation elements in the lifters must settle otherwise the valves will strike the pistons. |
| Brakes seem loose | marvins_dad | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 01-24-2006 05:48 PM |
| Side Passenger Mirror Loose & Swivels | viansa | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 10-03-2005 11:47 PM |
