Melted fuse box - NewBeetle.org Forums
Old 04-30-2006, 09:13 PM
Question Melted fuse box
I am looking to buy a '99 w/ I believe the 2.0 that has only 50,xxx miles on it for $2,500. The fuse box under the hood on the drivers side melted for some reason. When it did, I believe it caused the fans to quit working & then it of course overheated. The guy who owns it, my neighbor, replaced the panel & it starts right up now. Has this happened to anyone else(is it a common problem)? Would this be the reason the fans quit? He said now that it starts, it overheats because it is low on coolant(maybe blew a head gasket?). Do these have to have a special coolant? I know this is alot of ?'s but I want to make sure I'm not getting over my head w/ this. It has been parked in his driveway for at least a year that I know of. I appreciate your time & for any advise you can give me on this.
Old 04-30-2006, 11:33 PM
Thanks for the info. Do you know if the fuse(s) in that box are for the fans? I am relatively mechanically inclined so how long & difficult is it to change the waterpump(and timing belt since I have read on here to do both). I am going to get coolant for it tomorrow to see if it leaks from the head gasket or see if it is in the oil, but does it take special coolant other than what I can get @ an autoparts store? Thank you.
Old 05-01-2006, 12:08 AM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
The left one of the three green fuses is for the cooling fan as well as the center one of the metal strip fuses...
Old 05-01-2006, 01:13 AM
Thank ya'll for all the help.
Melted Fuse Box on top of Battery jiggseob Questions, Issues, Concerns, or Problems with the New Beetle 4 06-24-2007 06:56 AM
fuse box location? ChuckDubDub Questions, Issues, Concerns, or Problems with the New Beetle 4 08-16-2006 03:57 AM
blown fuse jacko Questions, Issues, Concerns, or Problems with the New Beetle 4 06-30-2006 12:51 AM
Fuse locations piper109 Technical Modifications 0 04-09-2006 06:31 PM
Help Please.Fuse for the raido slugo Questions, Issues, Concerns, or Problems with the New Beetle 0 01-23-2006 05:50 PM
