2001 VDub Air Conditioner Motor - NewBeetle.org Forums
Old 05-15-2006, 04:34 AM
ladyhawksguide's Avatar
Beluuuuga
Whittier, CA, USA
Car: Silver New Beetle - Sporty Girl
Unhappy 2001 VDub Air Conditioner Motor
The Motor on my 2001 VDub seems to have gone out! Just noticed the air was not cooling so I check the air conditioner and the motor is not turning. Does anyone know how to replace this yourself or how much I'm going to get screwed by the dealer to have them do it
Thanks for any help I can get!
Ladyhawksguide
Think Peace
Old 05-15-2006, 05:10 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
Before you do that, you should check a lot of other things. A few things to check would be:
Fluid level
high pressure switch
fan control module
cooling fans
a/c control switch
wire cable/plug to the a/c compressor
leaking hose
any of these can keep the a/c from working. A new a/c compressor from the dealer is going to cost your first born child. Suggest you contact a VW specialty shop or a/c shop for a checkup before just replacing things.
Old 05-16-2006, 01:41 AM
Beluuuuga
Whittier, CA, USA
Default Air Conditioner not working.
Thank you - sounds like good advice...
When I turn the fan on it does turn on - but no cold air. and when I turn the air cond switch on - it's a no go
I'll have my son check the switch - almost every other plastic part on the car has gone bad already... unbelieveable that they would make this car with so many cheap parts - geeez.
I just had my window switch replaced not 2 months ago (the window just fell on its own - luckily it did not break) and now the driver side switch is breaking. and my check engine light has been a perpetual beacon since I got the car!!!
Thanks for the list of to-do's
We'll start our way there - and if none of those work - I'll have my first born take the darn thing to the junk yard! Just when I was going to try and trade it in and at least get $500 for it - now I'll have to pay them to take it off my hands!
grrrrrrrrrrrrrrrrrrr I know drama queen!
Old 05-16-2006, 01:47 AM
gilligan's Avatar
MI, USA
Did you check the fuse? the clutch for the air is electric.
Old 05-16-2006, 05:52 AM
Central Coast, CA,
Car: 98 TDI NB.
Good point. Not only that fuse, but the ones on top of the battery as well.
Old 05-16-2006, 01:02 PM
For what it is worth, my daughter's NB A/C compressor just started making noise and I ordered a replacement from World Impex for $275. Also replacing the brake light switch and the valve cover gasket because of a small oil leak.
But I agree with others that there are several things that will prevent compressor from running such as fuses or low R134a charge. Also, I believe the radiator fans have to turn on before the A/C compressor will turn on.
Old 05-16-2006, 02:49 PM
bugdreamsdocometrue's Avatar
Got My Bug 04/29/06!!!
Sapulpa, OK, USA
Car: 1998 2.0L Cool White
Man!?! $275 for an A/C compressor? Kick A$$
For my 1991 Ford Ranger...$1400.
Well, with Cricket (that's the Ranger's name haha) having 250,000 miles on it, do YOU think it's worth $1400 to get a new a/c? ehh...NAH!!!
As for the OP question...I swear I think I remember somewhere that if you don't have enough refrigerant in the system, the fan won't run???
Is it possible to add some more...perhaps it's just out?
I'll check into that more tonight when hubby gets home. My Mercury Villager did *something* like that, and when we added refrigerant, it fixed it.
It was either low or the a/c switch was out, or both, but I don't want to steer you one way or the other without knowing for sure myself. haha
Kristi
It's all about the bug culture!!!
Old 05-17-2006, 03:53 AM
BigRedOne98's Avatar
LIC, NY,
Car: 1998 Red 5 spd. + Spoiler
I have a similar problem. When selecting AC, the fan kicks in, but no cold air, and noticed the AC compressor is not cycling on and and off. There's AC compressor switch on the left side upper corner of the engine bay, the book says to unplug it and jump the terminals 1 and 2 to run the compressor, havnt tried that yet. Most likely if no refrigerant pressure in the line the AC compressor will not kick in.
"Unless It's Fatal, It's No Big Deal"
Red 1998 NB, 97k SOLD SOLD SOLD
Old 05-17-2006, 05:35 PM
lucian's Avatar
member
STATEN ISLAND, NY, USA
Car: 99 Beetle
The VW dealer quoted me for 650 USD (AC compressor + install).
99 Beetle/2008 Rabbit
Old 05-18-2006, 11:45 AM
Central Coast, CA,
Car: 98 TDI NB.
Ouch!
Try calling an a/c specialty shop for a quote.
Old 05-18-2006, 10:26 PM
rcyRegistered Member rcy is offline
Save a horse, ride a....
Burlington, Ontario, Canada
Car: 2000 GLS, silver arrow
As someone already mentioned, make sure the 30amp fuse in the fuse box on top of the battery is not blown (or the fuse box itself has not melted). Do a search on the old forums for this - lotsa ppl had this problem. There are 3 (on my car anyway) green 30amp fuses in there and one of them controls the cooling fans. If the cooling fans don't come on, the A/C will not come on to prevent the system pressure from rising too high. This is an easy thing to check before you start messing around with jumping A/C switches, checking refrigerant pressures etc etc.
Old 05-18-2006, 11:40 PM
As I mentioned earlier in this thread I ordered a new compressor from World Impex. It arrived in 3 days and was the exact same model as was on the car! Again, $275, ordered on-line. I replaced the one on the car and it cools again just fine. Also replaced the valve cover gasket because of an oil leak and the vacuum hoses that attach behind the manifold just in case they were leaking. The compressor won't run if it is low on freon.
Old 05-19-2006, 03:45 AM
LIC, NY,
My Fans do kick in, when selecting AC.
Old 05-19-2006, 04:22 AM
Central Coast, CA,
Car: 98 TDI NB.
That switch you need to check is the high pressure switch. Just short pins 1 & 2 with a paper clip. If the compressor clutch does not engage, then you may have other problems. Check the wire harness going to the back of the compressor.
Old 05-19-2006, 09:28 PM
I'd suggest getting your system pressures checked next, then.
Old 11-07-2011, 04:27 AM
You replaced the compressor? Is that a very complicated procedure? Can you please discuss how you did it? Any info greatly appreciated. Thanks.
Old 11-08-2011, 07:57 PM
Well the A/C clutch not engaging doesn't mean your compressor is bad. There is a high pressure switch in the line which works like if the refrigerant pressure falls below a certain point the switch will turn off the compressor in order to protect it. Therefore in order to test the compressor or fill refrigerant you need to short the switch. You can find the method on Haynes manual or Bentley. If the compressor clutch still doesn't engage after you short the switch then the clutch is bad. Keep in mind that you can't run it for too long with low refrigerant because it will damage your compressor. Fill the refrigerant and PAG-46 oil as soon as possible and check for leaks. If there's a leak you probably have to evacuate the whole system after you fix the leakage.
Ladyhawksguide
Motor Oil FineExampl 2.0 Liter Gas 39 07-16-2010 09:30 PM
Try losing your VDUB like this... SPIRU Miscellaneous Hoo-Ha Archive 21 04-30-2006 07:31 AM
Air conditioner whisle savethebluths.org 2.0 Liter Gas 1 04-15-2006 03:06 PM
Vdub comic reference blockphi Miscellaneous Hoo-Ha Archive 7 12-30-2005 04:54 PM
Cold Air Intake CAI Ram air the Cheap way.... Pulgamovil Technical Modifications 11 11-05-2005 08:34 PM
