Thanks for putting up how to change the headlight bulbs. I had the dealer do one for me and it was under warranty on the passenger side but when the warranty expires looks like i would have to change it. Driver side must be a pain as the battery and air filter is in the way and looks to me i have to take apart these things in order to replace a bulb. Thanks for the tip i will try to remember how to do this
This is probably a REALLY silly question.
But WHERE is this "headlight assembly"?? Consider me an idiot- but do I open up the hood and look - where - to find this little button and lever to get the headlight out? *EDIT* My burned out headlight is on the driver's side. And I see now there's a bit more involved on that side. I was wondering why I couldn't find this switch do-hickie. The battery and so forth are both in the way on the driver's side. |
Thanks for the sanity check, I changed 1 before but I think the Drivers side was in wrong The slides were all burred up I about I had to pry it out.
Ihave a 1.9 TDI and the drivers side is easier to get out than the other My fuel filter blocks the passenger side. |
The driver side on the 2.0 is a little trickier, but it can be done without taking the battery out. You just got to look around in there so you can see where the lever and where that button-thingie is (yes, that is a technical term
). I used a wooden stick that I found near my car. It was just what I needed to get it pished in so I could move the lever. Yes, it's tight with the battery in place, but it can be done. |
So, my driver side headlight has burned out twice!! My husband just replaced the bulb, again....and again....but has informed me that there is a part inside which needs to be replaced. It looks like it goes around the inside and possibly has a clip which the light slides into. That part is broken. Dealer wants $150 for that part!! Anybody know where I can find it for less?
Thanks! Frances |
This thread belongs in the technical forum, there is hardly a thing about a 2.0 that makes it different from every other NB besides the motor and drivetrain. Please don't post body / trim related stuff in a motor-specific forum.
![]() SMG |
I do notice though , after I have broken the factory
install. the inside of the light ring rubber is not going back all the way in to the body. just a small gap now, any suggestions? maybe I did not place it like it says on #4 (the bottom small track) I will check today. |
thank you for all the info on how to do this. Even with that i managed to break the drivers side head light.... Turns out the previous owner glued the tracks with some kind of white glue.
time to buy new headlights i guess. Thanks again ![]()
Ich brauche Kraft!!!
ugg what a pain. got it.
did the little drill a hole, tap with screw driver, shake, pull, tap, spray tons of WD40 in, repeat... im sore. Once the light was out you can see this crappy plastic assembly. 3 easy bolts and it's out. what the frack.. the CAD, engineering and mold on this was way to complicated.. lol.. just bold that damn thing in!!! pfft. cleaned it up good.. lubed it. I should order another plastic magic thing, but i have to drive my car in the morning. o well, it will lock it's crappy ass back in when I'm done. getting it out again later? ya, who knows. |
First off, I love the pictures, very helpful. However when I got in to push the button and pull the lever, I found that the button had been broken by the last person who tried to replace the bulb. Also the lever is already in the down position. Could it be that the lamp assembly was just wedged back in place? Do I need to take the car into a shop to get this rectified? Anyone have some advice?
LET'S MAKE SURE HISTORY NEVER FORGETS THE NAME "NEW BEETLE" |
| 06 headlight removal | yelojkt | 2.5 Liter Gas | 19 | 06-13-2011 03:30 PM |
| AC Switch Removal | Buglover | 2.0 Liter Gas | 2 | 04-02-2006 09:07 PM |
| How-To - Snowbox Removal | marvins_dad | Technical How-To | 4 | 01-10-2006 06:28 PM |
| seat removal | nbdude | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 10-15-2005 07:41 PM |
