engine noise - NewBeetle.org Forums
Old 06-09-2006, 12:58 AM
Default engine noise
Hi I have a 99 beetle with the 2.0l 4cyl 75k miles and i have a very loud ticking noise (tick tick tick) from the engine. Hot or cold and it is engine speed related. I keep up on my oil changes, what could this noise be? someone told me it mught have to do with the valves? Thanks
Old 06-09-2006, 01:41 AM
BigRedOne98's Avatar
LIC, NY,
Car: 1998 Red 5 spd. + Spoiler
I would chek my oil level first even between oil changes, these engines tend to eat up some oil. Worst case, the sound can be coming from the valve terrain. Not sure how it is on the 2.0, but on my old Jetta the timing was off so I just had the distributor adjusted. I'm sure some one here will fill you in more.
"Unless It's Fatal, It's No Big Deal"
Red 1998 NB, 97k SOLD SOLD SOLD
Old 06-09-2006, 02:10 AM
The oil is at the proper level. I use 5W30 and am always topping it off because it does burn a little bit of oil.
Old 06-09-2006, 12:12 PM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
I'd have your timing belt checked. 75k is a bit early for a 2.0, I did mine at 83k, they say the belts last for 100k.. but ya never know with age.
Old 06-09-2006, 10:37 PM
I just had the water pump replaced the VW dealer said the timing belt didnt need to be replaced, could that be causing the noise...the work they did?
Old 06-17-2006, 02:36 AM
I have the exact same problem right now. I'm at 105,000kms with a brand new timing belt and water pump. The ticking sound increases with speed. The oil level is fine and just got an oil change.
Anyone have any advice?
Weird noise coming from engine - in front of driver side Blue_00_Beetle 1.8 Liter Turbo 17 11-04-2006 02:24 AM
Is THAT what that noise is ... fulltiltredhead 1.8 Liter Turbo 16 09-02-2006 03:36 AM
Suspension noise BozemanboB Questions, Issues, Concerns, or Problems with the New Beetle 2 04-08-2006 01:42 AM
another engine noise in my 2.0 - vag com callisto9 2.0 Liter Gas 12 11-16-2005 08:28 PM
Whining Engine Noise. loafimus 2.0 Liter Gas 4 11-16-2005 04:00 AM
