Oil filter ????? - NewBeetle.org Forums
Old 01-14-2007, 03:15 PM
DWRAT's Avatar
Phoenix, AZ,
Car: 2006 Harvest Moon, Pkg 2
Default Oil filter ?????
I can't find where the oil filter is.
can someone please help out?
Thanks
Old 01-14-2007, 07:44 PM
STDave's Avatar
Irving, TX, USA
Car: 03 Beetle 2.0 & 06 Beetle 2.5
Default filter
First remove the lower engine cover (4 torx screws) from under the front of car. It is right in the middle between radiator and engine block. It is a black plastic housing that holds the cartridge type filter.
Old 01-14-2007, 10:43 PM
DWRAT's Avatar
Phoenix, AZ,
Thank You!!!!!!!!!!!
Old 04-29-2011, 03:18 AM
woody95124's Avatar
volks r cool
san jose , CA,
Car: 2008 vert beetle
Default oil flter
no comment.....
Old 04-29-2011, 04:52 AM
OH, USA
Car: 03 GTI
Originally Posted by jsulen View Post
I'm a mechanic and if I can't get it off with slip joint oil filter pliers or my cups, then I just jam a screwdriver through and wrench off. So it is safe to do it.
The 2.5L uses a cartridge filter--slamming a screwdriver through it in this case would be bad, very bad.
Old 04-29-2011, 11:23 AM
2004NBTURBOS's Avatar
Peace Love & T.o.D.
Ocean View, DE, USA
Car: 1st 2000 GLX now 03.5 TS
UMhhhh.....Ok. glad you won't be working on my car.
Peace Love an T.o.D.
Old 04-30-2011, 10:58 AM
boogety boogety's Avatar
Boogety Boogety
Dallas!, TX, USA
Car: 2006 NBC
You must work at a dealership, then. This explains a lot...
2.5L Oil Filter dr427 2.5 Liter Gas 6 04-11-2012 08:12 PM
2.5 oil filter location. dirvin 2.5 Liter Gas 9 02-12-2008 12:01 PM
Oil Filter BeetleNoir 2.0 Liter Gas 14 10-05-2006 04:01 AM
Oil Filter RedLoveBug06 2.5 Liter Gas 1 09-06-2006 04:28 AM
Which Oil Filter to use on a 1.8 slugo Questions, Issues, Concerns, or Problems with the New Beetle 8 10-18-2005 01:14 AM
