Gas smell on my 07 bug. - NewBeetle.org Forums
Old 02-09-2007, 09:01 AM
07 SalSaREd
IA, USA
Car: 2007 2.5L 6-speed & Lexus IS250
Default Gas smell on my 07 bug.
My new beetle with 300 miles on it, gives too much of gas smell when I start the car and warm up. It smells like pure gasoline, and it's not the smog coming out of the car.. Has anyone else experienced the same problem? Also, is it normal to see the heater does not blow warm air when I am at idle, but blows heat when it's on the go?
Old 02-09-2007, 12:14 PM
blackonblack's Avatar
Howdy
Taylor, TX, USA
Car: 2003 GLX NBC, 06 NBC PKG2, 06 Golf
Not sure about the gas smell. They can produce a rawish fuel smell on cold start. Yhe heater is a known issue. There is a repair bulletin to resolve the heat problem. See your dealer.
Old 02-09-2007, 02:49 PM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
Car: 2006 KitchenAid Red NBC, '66 Ford Mustang
I have smelled the gas smell only like twice. No clue why.
Old 02-10-2007, 03:10 AM
07 SalSaREd
IA, USA
Thanks. I should take it to the dealer.. and I meant fuel smell.
Old 02-15-2007, 01:47 PM
Stealth Performance
Beaverton Oregon, USA
Car: Jaguar XJ6
was that after you ate @ taco bell
Old 02-16-2007, 12:47 AM
07 SalSaREd
IA, USA
Nah, it was after I ate turkey and some boiled eggs.yuk..
Old 12-11-2008, 06:55 AM
OR,
Car: 07 Beetle package 2
Exclamation beware
I noticed the slight smell of gas once and awhile,just as quick as I smelled it,it went away.This past saturday I was driving along and it got REALLY bad,so I pulled over and turned the car off,popped the hood and found that gas was spraying out of a line on the passenger side of the engine. I had to have it towed,so I get it back and the dealer said that some hose clamps had rubbed a hole in the main fuel line going to the fuel rail,these "clamps" had also nearly worn a hole in the coolant hose. My advice,if you smell gas,get it looked at. It was bad enough to have this happen,but the treatment from the dealer was awful,and a story all by itself.
Old 12-15-2008, 01:06 PM
FallinApartBoy's Avatar
I Want A 2.5T
Dayton, OH, USA
i smell an exhaust smell when my heater is on but my car isnt moving. could be described as a fuel smell. i always thought i just had a leak in my cat or something.
NB Smell punkpie The New Beetle Experience 58 07-28-2008 08:01 PM
A/C Funky Smell Hollywood 1.8 Liter Turbo 4 06-26-2006 10:04 PM
Daughter's 98 NB chugging smell gas mtmomof5 Questions, Issues, Concerns, or Problems with the New Beetle 3 04-23-2006 03:45 AM
Oooooooooh that smell, can't you smell that smell? from Margaritaville... Miscellaneous Hoo-Ha Archive 55 03-31-2006 02:41 PM
What Smell? jdesigns Jokes 5 03-25-2006 11:59 AM
