DIY Oil Change 2007 2.5lt engine - NewBeetle.org Forums
Old 07-29-2007, 11:18 PM
Danbike's Avatar
Bike British
Near the Cheeze Line, FIB Land, Illinois to others, USA
Car: 2010 GTI
Default DIY Oil Change 2007 2.5lt engine
Has anyone done an oil change themselves? I got my NB up in the air today, and in addition to the 12 point torx fittings, I found two large metric bolt heads. Do they have to come out also?
Triumphs forever, or at least as long as they run!
Old 08-06-2007, 01:03 AM
Danbike's Avatar
Bike British
Car: 2010 GTI
One added question, the oil filter housing does not have a 36MM boss, the drain opening is in a round boss. How do you grab the housing to loosen it for changing the filter?
Hope someone is doing this work themselves.
Oil leak after 1rst oil change. shafrs3 Questions, Issues, Concerns, or Problems with the New Beetle 13 04-09-2011 09:04 PM
Oil Change? chris22104 Questions, Issues, Concerns, or Problems with the New Beetle 1 07-13-2007 09:56 PM
DSG DIY fluid change post dunno513 Transmission Talk 4 02-02-2007 06:19 PM
DIY Oil & Filter change a snap mel72349 1.9 Liter TDI 7 11-14-2006 04:50 PM
