Oil Change Screw-Up - NewBeetle.org Forums
Old 09-13-2007, 09:26 PM
AirBugger's Avatar
bird-brained...
Yorkville, IL,
Car: 2006 Salsa Red NB Convertible
Default Oil Change Screw-Up
OK... So I did something not-so-bright... I changed my oil in my '06 vert to Mobil 1, but grabbed the wrong viscosity... (non-VW spec 10W30). Do I need to worry about changing it out to the VW-spec'd 0W40 right away, or can it just wait until the next time I change it? Do I run the risk of hurting anything if I go 5000 miles on this stuff or not?
Old 09-13-2007, 09:31 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
I don't really see a problem, i'm not an expert or anything, but i think all that will happen is you might burn some since it's not as thick. if you have any oil pressure problems, i wouldnt hesitate to swap it out and put something thicker in. But it's mobil 1, so you probably won't have a problem.
Old 09-14-2007, 06:26 AM
AirBugger's Avatar
bird-brained...
Yorkville, IL,
Thanks Toad... I had a feeling it was probably OK, but it helps to hear it from someone else!
Old 09-14-2007, 01:34 PM
noR's Avatar
Administrator
Jackson, MS, USA
I'd let it slide. I know 0w40 passes vw spec; but my owners manual requested 5w30 for me; 10w30 isn't TOO bad; just be real soft in the mornings. Give PLENTY of time for warm up before gettin' on it.
Piece of cake.
noR | me | Phrog
PHROG
Old 09-14-2007, 03:34 PM
AirBugger's Avatar
bird-brained...
Yorkville, IL,
Thanks noR- I appreciate the tip!
Oil leak after 1rst oil change. shafrs3 Questions, Issues, Concerns, or Problems with the New Beetle 13 04-09-2011 09:04 PM
First oil change! help? Green Arrow The Canada Corner 4 08-24-2007 05:20 PM
Oil change grail73 2.0 Liter Gas 1 08-25-2006 06:51 PM
Oil Change Dan_Man The Canada Corner 2 07-04-2006 05:04 PM
Changing my oil tomorrow, help me not screw it up! heyou Technical Modifications 18 06-14-2006 06:22 PM
