http://forums.vwvortex.com/zeropost?...how&id=3924020
MkV 2.5l V-Flow Introduction Sale $279 Shipped Limited Time Only! Introducing the V-Flow Intake System for the 2.5l VW Motors! With our continuing success with untouchable power and efficiency levels for intakes on the VW/Audi Group of vehicles, we are proud to bring the 2.5l V-Flow to VWVortex Members first. ![]() For another special treat, all three colors of silicone will be available during the introduction, and only black will be available once this special is over. This is your only chance to get the silicone in any color besides black! ![]() 5-7whp and 10-15wtq gains have been seen on 87oct 7-10whp and 15-18wtq gains have been seen on 91oct 8-13whp and 16-20wtq gains have been seen on 93oct **As always, results may vary depending on conditions. Dyno of 87oct runs: ![]() Installed: ![]() Since this is the first place we are introducing this kit, it is not available on our website so you have to call to place the order. We are open from 9am-5pm Arizona time (which is currently the same as Pacific). Due to the high volumes of orders, please allow 1-2 weeks for shipping. Thanks for looking!
Jim ![]() sold1998 silver arrow 2.0 5 speed- 1997 GTi VR6..its cliche http://rustisnotacrime.com |
Folks...any aftermarket "intake" is actually going to turn your intake into a "hot air intake." The stock intake draws from the fenderwell which makes it a "cold air intake." It also flows more and filters better than your little 2.5 will ever need. Many of these aftermarket intakes actually reduce filtering capacity and airflow.
They will provide no performance increase, and the reduced filtering capacity could actually harm your engine in the long run. The only thing an aftermarket intake does is make more noise...which only makes you think you have a power increase.
ah, dzlbug, how i love to talk shop with thee...
while you are correct that the aftermarket units are effectively warm air intakes, there is still performance gains to be had. the factory airbox on the gassers do NOT flow enough air up top for optimum performance. the air inlet is a 1.5" (if that) oval...hardly adequate. i have modified my factory airbox on my 2.0 by enlarging the inlet to a full 3", and extended tubing into the lower fenderwell. on my 2.5 swap, the factory airbox from the swap vehicle was not available, so i did not have that option. i instead acquired a 3" coupler, attached the maf to that, and put a filter directly off it. the 2.5 in the mk4 is a tight fit, a cai may be possible, but i have a warm air intake, and i notice no loss over stock. besides, who doesn't love the sound a vw makes uncorked? ![]()
If I wanted to do the same on my 2.0 NB, is it pretty easy to do |
| cold air intake vs ram air intake | xXRockyHorrorsXx | Styling Modifications | 33 | 09-03-2007 08:55 AM |
| Aftermarket Cold Air Intake | BeetleNoir | Technical Modifications | 23 | 07-19-2007 01:29 AM |
| cold air intake | xXRockyHorrorsXx | Technical Modifications | 13 | 06-13-2007 02:12 PM |
| Cold Air intake turbo S | DABarger | Technical Modifications | 1 | 10-30-2006 01:41 PM |
| Cold Air Intake CAI Ram air the Cheap way.... | Pulgamovil | Technical Modifications | 11 | 11-05-2005 08:34 PM |
