no heat - NewBeetle.org Forums
Old 02-21-2008, 10:28 PM
Sparta, KY, USA
Car: 2007 base
Default no heat
I have about 13,000 miles on my nB and the heat keeps going out when its idling. once i get going it comes back on any one got any ideas?
Old 02-22-2008, 02:14 AM
Maggadog's Avatar
A Touch of Gray
Foresthill, CA, USA
Car: 2006 Convertible
Take it into the dealer. I have the same problem with my '06. There is a TSB about this. It seems if the coolant expansion bottle is changed this problem goes away. Don't ask me why. This TSB, according to the service manager, just came out in late January or early February.
My dealer told me this part is back-ordered, so the sooner you get your NB to the dealer, the sooner the part will come in and the sooner you will have a nice warm cabin. The service manager told me there is about a 2-3 week wait for this part.
Old 02-23-2008, 04:01 PM
Ikkin's Avatar
Pinch my cheeks!
Da Burbs, IL, USA
Car: '06 NB Vert/Reflex Silver 5 sp
Heading to the dealer too!
I have the same problem. It's been SO cold here, i didn't really notice it, just assumed it was due to the cold.
thanks for the tip!
Old 02-23-2008, 05:04 PM
FlwrPwer's Avatar
Fishkill, NY, USA
Car: '07 Triple White NBC
Having the same problem with my 07 TW. Thought this was also due to the cold. Didn't realize it was an actual issue.
Thanks Guys!
Old 02-23-2008, 07:14 PM
Sparta, KY, USA
Car: 2007 base
thanks for the info! I'm gonna call my dealer on monday.
Old 02-24-2008, 08:32 PM
CLOTAGAMES's Avatar
ROCK FALLS, IL, USA
Car: 2007 PACKAGE 1
Default Heat Fix
Had the update done 2 weeks ago. Talked to the tech. System is prone to air bubbles. New expansion tank update fixes the issue.
Old 03-01-2008, 04:44 PM
Topless Forever's Avatar
One Day at a Time
New Minas, Nova Scotia, Canada
Car: 06 Mellow Yellow NBC
Had mine done in Nov before I salted it away for the winter.Cured
Old 03-06-2008, 01:40 AM
Ikkin's Avatar
Pinch my cheeks!
Da Burbs, IL, USA
Picked Pearl up this week, they did a flush, due to an air pocket/bubble.
I only have 8800 miles on her, and i asked why they would need to do a flush on that low of miles. The tech said that when they filled the car, when she was produced, it was done by a machine. (?)
When They, the dealer, do a fill, they use some piece that sucks the coolet in when needed. Something about the air in the system.
Not sure, but i do notice a difference with the heat.
Old 03-06-2008, 03:45 PM
Sparta, KY, USA
Car: 2007 base
my part is still on back order......go figure. the coldest season and I don't have heat at idle... I wish the service department was better. Hopefully I can get it fixed soon.
Old 03-09-2008, 07:44 PM
Ikkin's Avatar
Pinch my cheeks!
Da Burbs, IL, USA
the only thing that makes me nervous on this..
since we didn't have hot heat at idle, doesn't that mean the engine is not getting cooled as it should? I can't imagine that is good for it.
No issues on my service, and i'm a freak when leaving my baby with someone else. She had to stay outside all night! Oh the horrors!
Good luck on getting your part Soon!!
I hear Spring is next week.
Old 03-09-2008, 08:34 PM
Sparta, KY, USA
Car: 2007 base
i want spring! we just had15 inches of snow in two days! talk about a blizzard. really not good with out heat.
Old 03-28-2008, 02:59 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
I had this happen to me last night. Today is the day John is starting the radiator replacement. Should I have a new coolant expansion bottle installed too? I thought I was just low on coolant since I have a hole somewhere.
Old 12-06-2010, 07:53 PM
dedwards0323's Avatar
Upstate, SC, USA
Car: 2006 Platinum Gray Convertible
Took our 06 VW NB Ragtop in to local dealer this morning. Can't get the car to produce any heat during morning warm-ups at idle. Asked the Planner about TSB on coolant overflow jug. He verified that the TSB existed and would contact me if they couldn't find anything else. Got a phone call mid-afternoon that they were recommending to change out the overflow jug, based on the TSB. In addition, he said our VW had the old style coolant temp sensor & they'd recommend changing that also. Don't like changing 2 things at once because if problem goes away, what fixed it!
Car certainly acts like it has a vapor lock condition going on in the cooling system. Don't see why just a proper flush & system venting wouldn't fix the issue, as reported by Ikkin earlier in this thread. Wish I could find out what's so different about the new overflow jug?
Anyway, car had just over 59k so I asked them to perform 60k servicing. I provided oil & oil filter.
Hope to get our ragtop back late today as Berta wants her VW working properly. Because if Momma ain't happy, NOBODY is happy!!
Later,
2006 New Beetle Convertible 2.5; Purchase Date: 04/03/10
Platinum Gray w/Black Top; Gray Leatherette
Package #1; 6-spd Tiptronic; 6-Disc Changer
Wind Screen; Monster Mats; VW Chrome Exhaust Tips
Old 12-07-2010, 12:07 AM
Upstate, SC, USA
Got our 06 ragtop back this afternoon. And we've got heat!! Seems like the vapor lock condition associated with the overflow jug took care of the no heat problem.
Had the dealer change the cabin filter while the car was there today.
Bug should be ready to go for awhile now.
Old 12-29-2010, 07:17 PM
djeRegistered Member dje is offline
I've got the exact same problem as the OP here, although its not an issue of just being in idle, its whether or not you are moving.
I'f the car isn't moving, it blows ice cold. If I hit the gas while not moving, it blows ice cold. If I start moving, even 5 mph, the hot air is flowing. Thank god I'm in a warm weather area.
Anyone have any links to the TSB that addresses this?
I already took this into my dealer once, they said npf, but I'm in Florida and it was hot out when I had them check it.
Old 12-29-2010, 07:24 PM
MyOtherRidesAVette's Avatar
They never act up when you get them to the service department! LMAO
Sounds like a sensor somewhere. Is this ditto to the defroster? What about getting heat if you have the a/c turned on? Get out the Bentley!
MORAV
In der Automobil-Scheune
Old 12-29-2010, 07:29 PM
No clue on the defroster...not really an issue where I live.
But w/ the ac on vs off, doesn't make any difference.
No heat at all unless the car is moving. And it BARELY has to be moving. If its moving at all, the heat is just fine.
Old 12-29-2010, 07:46 PM
Where could you possibly live that the defroster is not an issue?
That aside, really sounds like a sensor or modulator going bad, possibly, but doubtful, a loose connection. Do you want to fix it, regardless of your need for heat or defrost? Member J.Arce will catch this post and put up a Bentley diagram, I'm betting! J...?
MORAV
Old 12-29-2010, 07:55 PM
I'm in west-central/south Florida. I don't even know where my defroster button is.
I just found another thread here while doing yet another google search on this issue. Seems I'm definitely not the only one with this problem.
No Heat when at a stop??
Old 12-29-2010, 08:09 PM
Thumbs up You may have just found your problem
There seems to be three totally different problems discussed in that thread.
No heat when the engine is cold is where some went! Duh...
Blend door issue... unrelated.
Your problem seems to be addressed most directly in Post #24. Not sure how anything in the a/c system is related to heat, but as you can get heat through the a/c system (how I always heat my vehicles, because the air is dried, and no none use of the system issues over the cooler months) I can see here the two could be related. That is where I would start.
MORAV
No Heat when at a stop?? Puddles Questions, Issues, Concerns, or Problems with the New Beetle 26 03-29-2011 03:20 AM
heat soak PsycologyNerd 1.8 Liter Turbo 23 02-25-2008 03:07 PM
A/C stuck on heat... 006 1.8 Liter Turbo 1 08-21-2007 10:52 PM
No heat of a/c SAMPO Questions, Issues, Concerns, or Problems with the New Beetle 22 04-04-2007 03:35 AM
The Heat and Cleaning? Barnum New Beetle Detailing/Cleaning 2 08-06-2006 06:16 PM
