cold heat on idle - NewBeetle.org Forums
Old 03-19-2008, 02:10 AM
Cool cold heat on idle
I have a 06 2.5l tip tronic which I love....heat works great, until I sit at idle then it turns cold.....anyone else have this problem, or just me?
Old 03-19-2008, 02:33 AM
Maggadog's Avatar
A Touch of Gray
Foresthill, CA, USA
Car: 2006 Convertible
There is a fix for this problem. Take it back to the dealer and have them replace the coolant expansion tank.
There is a thread with more info about this problem. Do a search on this site for "No Heat", and then click around a bit till you find it.
Old 03-19-2008, 06:49 PM
dasmurph's Avatar
Portland, OR, USA
Car: 2003 Jetta GL 2.0
I think there are 3 or 4 threads about this issue...but it is an easy fix that IS covered under warranty. Your dealer should know exactly what to do. I had the issue fixed on mine and it works fine now...good luck!
Old 03-20-2008, 01:06 AM
Default thanks for info
thanx for all the info on this....i shoulda looked around the site first but didn't know what to look under. I have an appt with my dealer to get it looked at.
no heat 07harvestmoon88 2.5 Liter Gas 27 01-12-2011 05:14 PM
bad idle when cold Ziggi 1.8 Liter Turbo 3 08-27-2007 06:46 PM
No heat of a/c SAMPO Questions, Issues, Concerns, or Problems with the New Beetle 22 04-04-2007 03:35 AM
Apply heat to your cold hatch latch...... rcarr67 The New Beetle Experience 2 01-17-2007 05:54 PM
Cold Misfire/Idle rough blackonblack 1.8 Liter Turbo 2 04-02-2006 04:31 PM
