Is it on the passenger side? I think I found it? Do you need to remove the bottom shield to get to it? If so, how many bolts must be removed? I see two in the rear and others at the front plus some screws in the middle. Could they make it any more difficult? Thanks Mike Last edited by mikejs27834; 06-28-2008 at 10:51 PM.. |
OK, timing is everything. I just did my 2007 Convertible this afternoon. Yes, I am anal rententive and have bought the special VW tool for draining the oil filter housing. I also use a PELA extractor since the shield on the soft top has 15 bolts that holds it in. I understand that the hard top has a much easier to remove shield, but driving with the top down is nice.
Total time to change the oil and filter was 15 minutes from when I started the extraction to when I was starting the engine. I only use Castrol Syntec, and yes I save my receipts, and VW filters. This really is an easy chore to finish. Plus you know that the dolt working for JXffy Lube won't cross thread anything.
Triumphs forever, or at least as long as they run! |
Find the oil pan. Drain plug is on the backside facing downward at an angle. It's centered. |
All (he is) saying...is give (war) a chance... [apologies to John Lennon] "Nibblin' on spongecake, watchin' the sun bake, all of those tourists covered in oil..." "Your Freudian slip is showing..." "Reality is just that surreal time between my dreams" - me |
"No trees were killed in the sending of this message but a large number of electrons were terribly inconvenienced." Kenny's Silver '04 NB Convertible GLS 1.8 Turbo http://newbeetle.org/forums/photos-new-beetles/25692-kennys-silver-04-nb-convertible-gls-1-8-turbo.html |
This might help, if you are like me... I need pictures.
http://forums.vwvortex.com/zerothread?id=2570457 |
Also make sure that you have an 8mm "triple square" male for the 6 undercarriage pan bolts. The 6 point torx will not do the job. You need a 12 point male type torx, which by the way it is not called torx... I found this out today. Cragen sells it, it's part of a kit made by Powerbuilt (#648599) Internal Wrench Set is what they call it. That's how you remove the bottom pan.
| Oil Change | Exigen | 2.0 Liter Gas | 18 | 05-21-2007 01:30 AM |
| Oil Change? | Luna Bug | 2.0 Liter Gas | 6 | 08-08-2006 12:43 PM |
| Oil Change??? | scoester | 1.8 Liter Turbo | 3 | 07-19-2006 04:50 PM |
