Strange noise? - NewBeetle.org Forums
Old 05-20-2008, 12:15 PM
redoodlebug's Avatar
McDonough, GA, USA
Car: 2007 Salsa Red "Tabasco"
Question Strange noise?
In addition to the higher rpm's and louder engine noise at start up (which I am told is normal), has anyone notice a whining noise when the engine runs at a constant 1200-1400 rpm? It only seems to occur at or through this rpm range. Its not a high pitched noise, sounds more like "wooooooo", but again only at this rpm level.
Old 05-20-2008, 05:59 PM
dasmurph's Avatar
Portland, OR, USA
Car: 2003 Jetta GL 2.0
Ya, both of my 2.5's make that noise and so have the other ones I've been in. Not sure what it is, but seems normal to me.
Old 11-06-2008, 06:25 PM
My bug was making the same noise after longer trips in warmer weather. The dealer replaced the fuel pump. The noise was a "whriing" sound like a fan left on coming from the engine compartment. This fixed the problem. However, I then uncovered another sound, like a traveling hum. They decided it was the fuel filter? under the rear seat. It's been quite since then, but the weather has been mild.
strange noise when turbo kicks in jc918t 1.8 Liter Turbo 88 10-08-2010 10:21 AM
Strange Window Noise jbthompson New Beetle Convertible 8 06-02-2008 05:29 PM
strange ticking noise mrsbeazley Transmission Talk 0 03-03-2008 11:44 AM
Strange Noise Casper is Making... bugdreamsdocometrue 2.0 Liter Gas 4 07-07-2007 06:39 AM
Bug's making a strange sloshing noise from the back! Shamrockez Questions, Issues, Concerns, or Problems with the New Beetle 10 12-07-2005 01:48 PM
