06 headlight removal - NewBeetle.org Forums
Old 12-03-2005, 08:05 PM
yelojkt's Avatar
beetle driver for life
Wichita, KS, USA
Default 06 headlight removal
Tools used 5mm 1/4" drive socket with a 8" extension
Passenger side
1. Find the locking bar head just under the first fender bolt. There will be a lock/unlock graphic in front of it. Turn it clockwise until it stops. Photos 2, 3 and 4.
2. Using your extension push down saftey catch tab (stamped stainless steel with an X on it). Photo 5. While holding tab down push head light out from behind. Make sure you hold your leg in front of headlight so it does not jump out onto floor. It comes out really easy.
3. Change bulb and reinstall.
4. Relock the lock bar and close hood.
Moded to make driver grin.
Did You see Yelojkt?
Dyno Video before custom K03S
09 ZX6R Candy Blue
Old 12-04-2005, 03:51 AM
Beetlebomb's Avatar
An Air-Cooled Fan, Too!
Olympia, WA, USA
Car: 2003 Platinum Grey Turbo S
Default Great, clear pics!
Man, these are great pics that literally diagram step by step how to change a headlight. Very good job, Yelojkt!
My 2003 platinum grey Turbo S.
Old 12-04-2005, 12:31 PM
Porkchop's Avatar
a.k.a. porkchopzz4
Cartersville, GA, USA
Car: '00 Silver GLS 2.0L auto
Hey, does the new "system" look less breakable than the older Beetles? Man.. if so, someone needs to come up with a retrofit kit
Old 12-04-2005, 10:08 PM
Pawleys Island, SC, USA
Car: 2006 New Beetle 2.5L 5-Speed Platinum Gray
Thumbs up Thanks! Great Pictures Too!
Thanks for the Full Detail Explanation! Great Pictures Too!
Old 12-28-2005, 02:19 AM
GatorBeetle's Avatar
Wendy 1974-2008 :(
Salisbury, MD, USA
Car: '06 RS GLI 6-Spd
I was able to remove mine in the '99 without breaking anything...and therefore the new way looks more complicated to me. Give me tabs and buttons any day...as long as they don't break...
Wendy Rotar 1974-2008
Online Memorial & Guest Book
Old 12-28-2005, 01:50 PM
dr427's Avatar
Very nice write up for hopefully 2 years down the road.
Are headlights covered under warranty for any length of time?
David
2006 Reflex Silver 2.5L 5sp Pkg 2
Old 03-26-2006, 04:17 AM
USA
Thumbs up Thanks
Thank you very much for your reply.
I'll buy tool and try to do it.
Thanks again
Old 06-01-2006, 12:59 AM
-1-'s Avatar
-1-Registered Member -1- is offline
All-American
Chester, VA, USA
Car: '06 NewBeetle TDI "Prius Eater"
Passenger side
Thanks to Yelojkt for his "how to" 2006 NewBeetle headlight assembly removal. I replaced the factory bulbs with Sylvania SilverStars today. The right side is easy but the left side is more difficult due to the close proximity of the "unlocking mechanism" and the "holding tab" with the battery cover and the air filter case. One big NOTE: the 2006 NewBeetle uses H7 bulbs and my old '99 NewBeetle used H1 bulbs. Once completed, the second time will be much easier.
......................-1-.......................
.............Prius Eater............
.'06 NewBeetle TDI .
My other car is a 2006 NewBeetle TDI
2006 NewBeetle Prius Eater
Old 11-07-2006, 08:19 AM
yodabug's Avatar
Heinz
Garland, TX, USA
Car: 2009
Lightbulb
Passenger side
CAN A MOD PLEASE MAKE THIS A STICKY????
Old 12-24-2006, 12:00 AM
Stealth Performance
Beaverton Oregon, USA
Car: Jaguar XJ6
Thumbs up
Just put in piaa H7's hi and low beams
and piaa H11's in the fogs
thanks for the R&R tips
Old 09-27-2007, 04:55 AM
hadda61beetle's Avatar
Greenleaf, WI, USA
Car: '07 Laser Blue NBC; '05 Passat Wagon TDI; '99 Ford F-150 4x4; '23 Ford T-Bucket
Gotta tell you, changing out the bulbs in my wife's 2005 VW Passat was way easier than I think it's going to be with my 2007 NB Vert. Holy frights what a mess to get to just to change out the bulb. Hopefully they will last for quite some time.
Jerry
Old 10-01-2007, 02:23 PM
Headlights are covered under warranty for the duration of the New Car Warranty....in Canada, it's 4 Years or 80,000km. Any other bulbs are wear and tear and are not covered after 1 year or 20,000km.
Old 04-07-2008, 01:23 AM
HighCompression's Avatar
Awesome Job!!!!!
Old 04-07-2008, 01:30 AM
Awesome Job!!!!!
I posted in another place on the forum that I was in the middle of this job and LOSING MY MIND. Then I found this.
BTW, mine was the driver's (battery) side. The only difference is that the "x" tab (the safety catch) is extended so that it can be seen from above if you look DOWN between the back of the battery box and the front of the air filter housing. It's a silver tab on my car and it's seems kind of flimsy, but if you push down gently it will unlock.
This seems like an honest improvement over the older NB headlights and once you have tried this and used these photos to do it, it's really easy. The only tricky part is trying to get the 5mm socket on the "lock".
Thanks a million for this help.
Old 05-26-2008, 01:04 AM
kds's Avatar
kdsRegistered Member kds is offline
WA, USA
Car: 2006 2.5L hb platinum grey
Red face 2006 headlight
Okay, this is a great thread. Unfortunately I am still having problems. Where is the X? I'm working on the passenger side.
Old 12-19-2008, 12:17 AM
mightywong's Avatar
Grayson, GA, USA
Car: 2007 2.5L
Default The X on the passenger & driver sides of a 2007 2.5L
I've got a 2007 2.5L and the X (on the passenger side) is about 8 inches toward the cab from the unlocking bolt. It's hard to tell in the picture, but photo 5 is looking straight down into the engine compartment. In the 2007 model, you can follow the windshield wiper refill pipe straight down and you should see the X tab.
One note, though, on the 2007 driver's side... there is no X tab. The safety release is tiny and almost impossible to get to without removing the battery. It can be done, but you'll have to look very closely between the battery and the air filter housing... underneath the two you should see a little silver metal prong. Use a long screwdriver or something to push it down a little and the headlight housing should slide out (as long as you've already unlocked the bolt, of course).
BTW, this really was a great picture tutorial. I'd have never figured out how to do this repair without it!
Old 01-15-2009, 12:08 PM
redoodlebug's Avatar
McDonough, GA, USA
Car: 2007 Salsa Red "Tabasco"
Thumbs up Good tip!!
Thanks for the tip (above) concerning the release tab on the drivers side. Made changing out the bulb on my 07 last night much easier. You're right, the tab on the drivers side is not obviously marked, but after reading your remarks concerning its location I found it on the first try. Good tip!!
Old 02-07-2009, 04:27 PM
azspeedbuggy's Avatar
Tucson, AZ, USA
Car: 2005 TDI NB white in color
2005 NB TDI driver's side headlight is burnt out. being a 2005, it's different from your 2006 NB...doesn't anyone know the procedures on a 2005?
I didn't see the lock bolt head as shown in the pictures. any help would be great...this is my first post, thanks.
AZSpeedBuggy from Tucson Arizona
Old 02-11-2011, 08:40 PM
Fayetteville, TN, USA
Car: 2006 Convertible
Default I love you.
You just saved me 80 bucks. I looked all over the internet to find out what the "secret" was to replacing the 2006 model's headlight bulb, and your great instructions and pictures saved me. I had mechanics that couldn't do it, and mechanics who insisted that the battery would have to be removed, but thanks to you I can just go get the exact tools i need and do it myself. Thanks a lot.
Old 06-13-2011, 03:30 PM
Does anyone know if I can follow these directions for a 2009 model? Last night I found the 5mm lock bolt, but didn't see the "X" tab... then again, I didn't know what I was looking for. Thanks.
Yucky tar - removal?? CoriBug New Beetle Detailing/Cleaning 15 12-21-2005 01:23 AM
Coolant flange Removal Tuckervill Questions, Issues, Concerns, or Problems with the New Beetle 1 11-28-2005 12:11 AM
center cap removal FineExampl Styling Modifications 2 11-23-2005 01:03 PM
seat removal nbdude Questions, Issues, Concerns, or Problems with the New Beetle 0 10-15-2005 07:41 PM
Front Grill Removal - How-To marvins_dad Styling How-To's 1 09-17-2005 04:22 AM
