Under Dash Light - NewBeetle.org Forums
Old 08-10-2008, 04:48 AM
Canada
Car: 2007 Relfex Silver NB
Question Under Dash Light
I have noticed that my 2007 beetle is missing a light under the dash that lights the tray infront of the shifter. There is light on the 2006 beetles but only a whole where i can feel wire's inside on mine. Can any other 2007 driver confirm if they have this light?
Dealer ship "says" it's not on the 2007's but then why the whole where it should be?
I feel i'm being BS'd.
Old 08-10-2008, 05:21 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
It could have been deleted due to decontenting. Since I don't own a NB past '05 I can't verify if it is there or not.
Previously:
Old 08-19-2008, 11:27 PM
Canada
Unhappy
Thanks Deserion,
Any 2007 drivers out there.....
Old 09-14-2008, 10:57 PM
My Mom has a 2008 New Beetle Convertible, and yes, the light has been deleted due to de-contenting. However, you are able to add the light to your car easily. The part numbers are as follows:
It is inexpensive to install the light bar that goes under the climate controls. I did it in my Mom's 2008 Convertible. The part numbers are below...essentially all you do is use 2 Scotch Lock tap connectors and splice into the wiring for the other dashboard illumination.
Part Numbers:
Light Bar: 1C0-919-390
Connector: 1H0-973-121-C
Wire Set: 000-979-131-A
If you need these parts, let me know and I can get them for you.
Cheers;
Peter
Old 12-26-2008, 03:31 PM
hadda61beetle's Avatar
Greenleaf, WI, USA
Car: '07 Laser Blue NBC; '05 Passat Wagon TDI; '99 Ford F-150 4x4; '23 Ford T-Bucket
Default Well then I'm not going crazy.....
Peter,
Wow....sorry for the "very late posting." I just now did see this posting regarding the under dash lighting.
I have the same dilemma. I have an '07 NBC and noticed that I have a "slit" of red light emitting from under the dash onto the item VW calls the Ipod compartment. I too thought that VW Mexico left something off of Henry.
So where does one obtain the parts that you have listed in your posting here?
One further question, did the VW NB at one time have the warning lights in the doors? I have red reflectors and it really seems that at one time these were actual lights.
Thank you in advance for your responses.
Jerry
Old 12-27-2008, 05:35 AM
Deserion's Avatar
Moddin' Lion
Yes, but when the 2006 revision came, the puddle lamps left with the previous style.
Old 12-27-2008, 11:14 PM
Greenleaf, WI, USA
Part Numbers:
Cheers;
Peter
Anyone on the org here happen to know where Peter is getting his parts numbers from and where the source is located for these parts? I have a "slit" of a red light below the climate controls...be nice to have more light down there even if it is RED. Speaking of RED...hope everyone had a very MERRY CHRISTMAS!
Again I look forward to reading the responses and thank you in advance.
Jerry
Old 09-01-2009, 04:51 PM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
I found an "Ashtray Light" in a donor car at the local salvage yard for a dollar or two. Got the light and pigtail. I further modified my light by removing the one LED and replacing it with three high bright red 3mm LED's (tops filed down about 1mm) with 510 Ohm resistor in series. Just tied the wires into an adjacent switches dimmer wires.
Tom
What does this light on the dash mean? fulltiltredhead Questions, Issues, Concerns, or Problems with the New Beetle 3 09-13-2007 02:48 AM
Air Bag light is on...smoke from dash davierik Questions, Issues, Concerns, or Problems with the New Beetle 0 09-04-2007 02:22 AM
Connecting dash light to DRL? Lmhansen Technical Modifications 1 09-11-2006 10:28 PM
strange dash light czaraj1@mac.com New Member Forum 8 06-08-2006 02:15 AM
WANTED: Under dash light Duffy Market Place Archives 9 12-16-2005 10:25 AM
