Whats up with my headlights??? - NewBeetle.org Forums
Old 04-06-2009, 12:18 PM
redoodlebug's Avatar
McDonough, GA, USA
Car: 2007 Salsa Red "Tabasco"
Default Whats up with my headlights???
My 07 Beetle is eating headlights like there is no tomorrow! Since January I have replaced both left and right low beams....twice! I'm very careful when replacing to avoid touching the bulbs as I am aware that causes them to blow. I'm using Sylvania SilverStar bulbs. Any idea as to whats going on, or maybe a suggestion of a better brand replacement?
Old 04-06-2009, 03:26 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
There is your problem. Silverstars seem to have very poor life, particularly in the H1 application likely due to the small size of the bulb and the resulting higher temps. The coating on these bulbs increases the temp.
Use plain old regular halogen bulbs, problem solved.
2000 New Beetle GLS TDI
Old 04-06-2009, 03:42 PM
McDonough, GA, USA
My 07 takes the H7 bulb. I've replaced low beams on both sides twice since January, and ironically both sides are burning out within a couple days of each other. That seems strange to me.
Old 04-08-2009, 11:29 PM
boogety boogety's Avatar
Boogety Boogety
Dallas!, TX, USA
Car: 2006 NBC
It's probably not the Silverstars, I have had them and still have them on all my vehicles, and not one of them has ever burned out on me. Ever. I like to change the fogs to match, too, and sure, they don't get as much use as the headlights, but even there... never a change required. So I'm talking a small sample here (sixteen over the years), but still, I'm batting 100%.
I do have a ScanGage II, though, and I've attached it to the OBDII port on each of my vehicles just to see what they do... and both my '03 and '06 NBCs exhibit a wild range of voltages, from 11.5v to 14.5v, swinging back and forth when stopped or driving for no obvious reason. None of the other vehicles I've monitored exhibit such a variance, although everything seems to work in the NBs with no apparent lights dimming, radio volume changing, etc. So, as long as everything works, I don't care. So consider that, for whatever it's worth, that's my observations...
Old 04-09-2009, 08:33 PM
McDonough, GA, USA
I've used SilverStars in my other cars with much success, so I dont think its a brand issue. The car doesnt show signs of any other electrical issues. As a matter of fact, other than the headlights I havent had to replace another single bulb on the entire car (of course 4 bulbs @$20 each since January is enough). If the problem continues I guess I'll have no choice but to take it to the stealership and see if they can figure it out (fat chance huh).
Old 04-09-2009, 11:56 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
I was changing mine left & right waaaay too often. Then I bought a bunch at once from an orger and they stopped going out . I did just replace the pass side the other day though.
Old 04-10-2009, 01:04 PM
noR's Avatar
Administrator
Jackson, MS, USA
I use a $7 bulb from advanced autoparts. Recommend you try them.
After a decade of ownership here's what I think the problem really is though:
There's some kinda drain on the system at random intervals. Some pump or some system 'powering up' which drains alot from the system. I'd get these "brown outs" where the headlights would dim and then come back up to full power.
I think the silverstars are built to expect a constant voltage; but when that spike hits, it doesn't really handle it super well.
Maybe you know enough electrical voodoo to add an in-line capaciter; I think that would "fix the headlights" ... but I still think the larger issue is elsewhere. And I've never seen it solved 100%.
noR | me | Phrog
PHROG
Old 04-10-2009, 03:46 PM
McDonough, GA, USA
Nope, no knowledge of any electrical voodoo on my end, other than having a good idea that 4 headlights in less than 3 months sounds like there's an electrical gremlin in the system somewhere. On my next replacement (and at this point its inevitable) I'm going to check out those $7 bulbs at Advanced.
Old 04-26-2009, 04:14 AM
Keep on keepin on!
Los Angeles, CA, USA
Car: 2008
i have an 08. bought the Silverstars caues the idiot at the part store said they have better life than the ULTRAs.
4 months and they burned out. replaced them with a JP buld which over heated and melted the glass (distorted). Now i have the Ultras in and we'll see how long they last.
I am a light-guy, i like knowing that i have better vision on the road but something tells me that the NB doesnt like change...
Old 04-26-2009, 04:32 AM
FarrisK's Avatar
Semi-Lurk Mode: GOOOOO
West Richland, WA, USA
Car: 2004 Ford Focus ZX3
It's funny you say that, Ron. I've noticed that when I first push on the window switch my headlights dim a bit. I wonder if that's the drain that causes the SS's to die?
Also, it seems to help if I run my fogs on all the time. I know it's probably not the best thing to do for other drivers, but it's become second nature to turn clockwise and pull when I turn on the headlights.
2004 Ford Focus ZX3
Drive more, worry less.
Old 04-26-2009, 04:50 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
I had Silverstars in the '05 and the '03. Both cars blew them within 6 months (in one case, both headlights on the '05 went within a week of each other).
Went back to OEM-equipped bulbs and have been fine since.
Previously:
Old 05-11-2009, 01:05 AM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
Car: 2006 KitchenAid Red NBC, '66 Ford Mustang
my low beams are not working tonight,seems strange they both went out at the same time, is this common?
Old 05-11-2009, 01:10 AM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
I noticed my headlights dimmed when I would use the all windows up button.
Old 05-11-2009, 01:11 AM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
Is changing the bulb something I could actually do?
Old 11-03-2009, 07:22 PM
Keep on keepin on!
Car: 2008
When i had my Silver Stars, that happened to me within 24 hours... that makes me believe that it is NOT the bulb but some sort of currency issue. Since i put my ULTRAS in in April i haven't had an issue.
I dont know if they are common... its not hard to swap out the bulbs on my year,2008. just have to know how it works.
Old 11-03-2009, 07:45 PM
Beetlecup's Avatar
senior member
Tampa / St. Petersburg, FL, USA
Car: 2003 Turbo S
Yes that is normal. The fix is to ground the battery better–Running a wire from the battery to the sub frame will do the trick.
Just don't get zapped!
Old 11-18-2009, 05:23 PM
Judee's Avatar
I Love Hippos.
San Diego, CA,
Car: 2008 Beetle S
I installed HIDs... no more burnt bulbs.
I figured by the time I changed the bulbs twice, it would have cost the same if I bought an HID kit.
I think the DRLs contribute to the "shortened" bulb life as well. Bulbs are designed to burn for X number of hours. Most cars use a different bulb for the DRLs, but our 2.5L Beetles use the same bulb for low beams and DRLs... so that X gets chewed up anytime we drive the car, including during daylight hours.
Old 12-06-2009, 07:52 PM
eliteboi's Avatar
Denver, CO, CO, USA
Car: 1995 Saab 9000 CSE- 200 HP and counting!
I replaced my bulbs a month ago with the Silver Star Ultras, let me just say, I will never... Repeat NEVER replace my headlight bulbs again, it took about 6 hours of prying and hearing plastic breaking to my headlights out!
That said, now my headlights don't really line up with the body anymore...
Hardey's MoToRwErKs- The only place to trust your VW/Audi to in Metro Denver
Old 12-06-2009, 09:01 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
Well, I didn't opt for silverstars, but i got el-cheapo blue bulbs when i first got my bug, and they blew so fast it wasn't funny (not even a week or so). I put the regulars back in after the free replacements i got blew. I disabled the DRLs a little later. Then I bought some USED PIAA hyper white and yellow (low bean and high beam respectively) bulbs and they never blew. I was quite shocked about that, although the disabled DRLs probably helped a lot.
One of them even stood up after the accident.
Old 12-06-2009, 11:39 PM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Turning bulbs on and off kills them, too. You can save yourself 1/2 the number of on/off cyles by starting the car with the parking brake set.
'02 & '05 Acura RSX
Dodge Cummins, Ford Ranger
M151 Ford
Whats this ??? bugsy98nb Questions, Issues, Concerns, or Problems with the New Beetle 11 03-09-2007 08:35 PM
Whats Mean? DUENDEPUNKER 1.8 Liter Turbo 7 12-15-2006 09:23 PM
Whats up? No (new) NBs anywhere. -1- Miscellaneous Hoo-Ha Archive 8 03-03-2006 08:31 PM
Whats the quieckest 2.0 around? degny21 Technical Modifications 28 01-07-2006 08:58 PM
Whats Next?? HungLo The New Beetle Experience 1 10-15-2005 06:06 AM
