Freezing Warning signal - NewBeetle.org Forums
Old 06-08-2009, 07:43 AM
UnBeetable69's Avatar
Default Freezing Warning signal
whenever i start my car for the first time of the day the warning signal comes on saying to be careful of ice on the road. But this is going off even when its well above freezing. How should i fix this? is anyone else having this problem?
Old 06-08-2009, 08:12 AM
Fowvay's Avatar
Moderation in Moderation
Berea, OH, USA
w00t it's the return of the mystery snowflake. This is a common issue with our lil bugs. It's a digital read out with an analog input. The numbers on the thermometer have to physically pass from 43 to 44 F *or something close to that* before the snowflake will go off.
So lets say it was 41*F when you turned your car off. Next day you start it up and it's now 70* outside. Well it will start from it's last registered reading and climb up but instead of going 41 42 43 44 45 etc it will jump 41 50 60 65 66 67 68 69 70. Therefore jumping right past the trigger and the snowflake stays lit.
I have a picture on my old computer of my car reading 117*F and still showing the snowflake. It's quite amusing actually.
Old 06-13-2009, 05:07 AM
so is there no way to fix it
Old 06-15-2009, 07:20 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
Use a cryo spray on the temp sensor (while the car is on) and let it warm up?
Previously:
Is anybody out there freezing as well? HerBee Miscellaneous Hoo-Ha 38 12-19-2008 10:38 AM
Signal Tinkerbell 2.5 Liter Gas 9 07-26-2008 09:14 PM
ESP Warning on mmagenta Questions, Issues, Concerns, or Problems with the New Beetle 0 01-16-2008 06:45 PM
Father charged in freezing death of 23-month-old girl.. PhoenixRising Miscellaneous Hoo-Ha Archive 23 02-13-2007 01:03 PM
Warning to PA Drivers pdoel Event Planning Archive 11 02-02-2006 01:46 PM
