Changing the Spark Plugs - NewBeetle.org Forums
Old 11-10-2009, 01:28 PM
Independence, MO, USA
Car: 2006 Convertible, Aquarius Blue
Default Changing the Spark Plugs
Hi All,
According the maintenance book, it's time to change the spark plugs in my wifes 2006, 2.5L convertible. Does anyone have any tips or pics for how to do this?
Thanks,
John
Old 11-17-2009, 01:12 PM
marvin2006's Avatar
Volkswagen Pilot
Elgin , TX, USA
Car: look at my avatar, yeehaw!
Hey there, I just did this two weeks ago and it turned out great.
Made a HUGE difference in the way He ran.
I have the Bently for the car, that is where the info came from.
First, unplug the wire harness from its connection to the main connection.
Basically, you have to gently pry the individual coil-packs up 3/8in, then disconnect the wire harness from each one. After the harness is disconnected, set it out of the way.
Then gently pry up each coil-pack with two screw drivers (be careful not to break off the side tabs) until they are free then set them aside in the order they came out. They are just pressed on so they are not really hard to pull out.
Then using a 5/8 spark plug socket remove each plug.
With the complexity of the operation, use the best plugs you can buy so you don't have to repeat often.
I am really glad I did mine, it was a huge change.
There is a special tool you can buy to replace the two screwdrivers by the way... I didn't.
New Beetle Pilot
Old 04-16-2011, 11:45 PM
woody95124's Avatar
volks r cool
san jose , CA,
Car: 2008 vert beetle
Default spark plugs
What part# or type is best for a 2008 beetle 2.5 motor????I heard NGK"S are the ones required...thnx in advance
Changing spark plugs AK Red Bug 2.0 Liter Gas 10 12-14-2008 11:59 PM
A/C Wont work after changing spark plugs YellowBug1991 2.0 Liter Gas 5 09-09-2008 05:04 PM
Changing spark plugs on 2.0 Cricket Questions, Issues, Concerns, or Problems with the New Beetle 2 11-04-2007 06:35 PM
I tried changing my own spark plugs :( Kitchen 2.0 Liter Gas 13 06-09-2007 03:29 PM
NB Won't Start after Changing Spark Plugs kev716 Questions, Issues, Concerns, or Problems with the New Beetle 2 05-30-2006 04:56 PM
