just a question from a 2,0 owner looking toswap - NewBeetle.org Forums
Old 12-08-2009, 04:34 AM
V_BFW_W's Avatar
levittown, PA, USA
Car: 98 red at bug
Question just a question from a 2,0 owner looking toswap
how hard is it to do the swap from a 98 2.0 to a 2.5
i also want to make it a stick and turbo it
is there a stock turbo for the 2.5 or will i have to get a aftermarket one
Old 12-08-2009, 05:29 AM
Just get a better car I think. I can see a swap being doable.. Even turboing your car would be fine but I can see that setup running you $10-15K easily and you could have something nicer for that kind of cash.
Old 12-08-2009, 07:59 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
There are turbo kits available for the 2.5L motor. I haven't done much research on them but I've heard okay things.
For what it's worth, installing the 2.5L is more work than it's really worth, to me. Not only are you swapping the engine, but also the cluster/ECU (different redline, for example), P/S pump reservoir, airbox, etc. Might be a better proposition to get a car that already has the engine you want, and you know it'll run right, and be cheaper, versus yours that may not run perfect and costs you more.
Previously:
Old 12-08-2009, 11:13 AM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2013 Kia Rio-5
Sell it.. buy something else. Not worth the trouble... unless of course you are 'UBER' loaded with cash and have nothing better to do.
Old 12-08-2009, 02:25 PM
Terre Haute, IN, USA
Car: 1999 Beetle TDI, 1990 Audi CQ, 2002 Audi A4 6mtq, 2000 VW Pointer
For the trouble, i'd swap a VR6 and boost that personally.
Or sell your 2.0 and buy a 1.8t they have a good amount of potential.
Old 12-08-2009, 02:55 PM
OH, USA
Car: 03 GTI
Here's a good rule of thumb an old hot-rodder told me once: "Don't build a car you can buy."
Why? It's always cheaper and less hassle in the long run. You want a 2.5L to turbo it? Buy a newer car w/ a 2.5L; you just want more power? best bang for the buck is to get a 1.8T; just want to spend yourself into the poorhouse? swap in a VR6 and twin turbo it!
Old 12-09-2009, 12:05 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
i've done it!
i swapped a 2006 beetle motor into a 2001 jetta wagon.
i have 9,000 miles thus far on the swap, and no issues. i could write a book though, but if you really want to know...
Old 12-10-2009, 03:50 AM
Judee's Avatar
I Love Hippos.
San Diego, CA,
Car: 2008 Beetle S
@ Cheat: Ever done a VR6 6-Speed swap into a 2.5L Auto body?
Old 12-10-2009, 07:15 AM
V_BFW_W's Avatar
levittown, PA, USA
Car: 98 red at bug
ok so it is petty much a bad idea huh even if i get the motor n trans for cheap. and if im gonna spend that much time i should just put a vr6 and boost that?
Old 12-10-2009, 01:53 PM
antonym's Avatar
¯\_(ツ)_/¯ (o\_l_/o)
Car: 2013 Kia Rio-5
you got it... also.. if you are going to spend that much time and opt for the vr6 and boost.... just write a blank cheque/check ...
Old 01-07-2010, 11:01 PM
The Cheat's Avatar
to me!
i've been doing a few different mk4 motor swaps right now (all in different stages of payment/disassembly), and i'm fast becoming partial to the 2.5.
i just finished another 2.5/6spd swap, this time it took 2 days instead of 5 weeks like the first time around. i was even able to recode the cluster to accept the 5cyl tach input, thereby saving about $300 or so.
the next swap that's slated to finish is a 3.2l/dsg swap into an auto 2.0 jetta, it's gonna be fun (if i can code the haldex out of the ecu/tcu).
Old 01-08-2010, 01:47 PM
Ayy! Chicky Chicky
Louisville, KY, USA
Car: 2003 VR6 GTI, 2002 Jetta 1.8T, 1988 Cabriolet.
I don't know what the differences are, but C2motorsports does a 2.5 turbo kit for the MKV Rabbit.
As far as the swap goes, I've always been a fan of "Don't build a car you can buy" unless your motor is shot, and you aren't working on your only car I would just find one you like with the motor you want in it.
Old 01-08-2010, 02:06 PM
The Cheat's Avatar
the c2 kit does fit the beetle's 2.5, the intercooler piping is modified, but it does fit, and jeff can write the software for you.
new nb owner w/question ecollin1 2.0 Liter Gas 6 10-06-2008 11:13 PM
new beetle owner question BugLover205 The New Beetle Experience 4 08-08-2008 07:12 PM
New vert owner with a question... GalacticTurbo New Member Forum 5 04-11-2007 02:26 AM
New Beetle owner question gcuster New Member Forum 3 08-06-2006 11:22 PM
New TDI Owner - quick question.. jhillestad 1.9 Liter TDI 19 12-06-2005 04:22 PM
