I've always run synthetic oils, trying to decide if I'll switch the NBC over. I haven't done any research yet but does anyone here run synthetic?
I am partial to Royal Purple. Anyone run anything different? |
We have oil service kits avialable that include VW 502 approved Pentosin Oil along with a filter and drain plug. They can be found here on the website for the 2.5L cars:
Volkswagen New Beetle 2.5L > Maintenance > Engine > Service Kits - ECS Tuning Inc ![]()
http://www.ecstuning.com :: Email: sales@ecstuning.com :: Facebook :: Questions? PM or Email for the quickest response! |
Ive switched over to fully synthetic with my 99 turbo with 132k miles. no leaks idles wayyy smoother. also I always thought any car above year 2000 requires fully synthetic. but ive done so much research about switching over and took the risk. people warned about leaks but thats if the car had leaks before and the fully synthetic just finds em. also royal purple is made for racing cars so you will feel the difference when you switch over. when i switched over my RPM was a bit higher, but i guess it was getting used to the new oil. =) hope any input helps? haha
![]() Just wanted to know if 2.5l owners saw benefits. This is my first German car. |
Been running Mobil1 from the start, 7 miles on the odo. and changed every 5K. I knew I was not going to ever get rid of the car so I invested that way. All the fluids I change in advance of recommended intervals, including & especially this 6 speed tranny that VW says doesn't require a change of fluid. That I assume is so we can all buy that new $3000 new one. The valve body is aluminum and typically goes at around 80/90K and cost $1100. Synthetic all the way! The investment now is worth a bit of peace of mind for me.
Hello,
I run Mobil 15,000 mile oil, I think it's about $28.00 for a 5 qt. jug, and $7.00 for the extra qt. at Walmart cause my 08 2.5 uses 6qts. I run 15K at oil change intervals and it is a top full synthetic oil. I run the mobil filter but the Mobil site says any filter works just as good. I run it in my 07 Wrangler 4 door as well and it is a good oil, I used to run all Valvoline, and it's hard to beat but I trust Mobil and they stand behind their oil on engine falure if it should ever happen. Good Luck |
| Which Synthetic oil to use?? | Reflex_2001.5_Sport | 1.8 Liter Turbo | 75 | 09-25-2011 04:34 AM |
| Synthetic Oil in NB? | Woodstock | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 08-24-2009 05:11 PM |
| Switching to Synthetic | jbthompson | 2.0 Liter Gas | 6 | 11-12-2007 03:27 PM |
| Anyone run Royal Purple Synthetic in their 1.8t??? | BooBah | 1.8 Liter Turbo | 5 | 04-17-2007 12:15 AM |
| Synthetic Oil? | v_dubyagirl | Technical Modifications | 9 | 10-10-2005 04:18 AM |
