just buy a mk4 gti exhaust for a 1.8t. yes, it'll fit (as long as it's for a turndown valance).
probably lose a ton of low-end, but up top, it would SCREAM. |
Volkswagen New Beetle 2.5L > Exhaust > Cat Back > ES#2866 Silverline Cat Back System - SDF2440
I've been looking at this one...but probably for next summer. |
Anyone familiar with this exhaust?? Tsudo 1999-2005 Volkswagen MK4 Jetta Golf GTI 1.8T 3" Performance Catback w/ Downpipe Turboback Exhaust System Wicked Tuning |
OK... So after some serious research on the Interwebs, and the expiration of warranty, I decided I had to go with the custom route. Given the price of 3" kits online, I figured I had a lot of budget to work-with.
I'm currently running a 3" mandrel-bent pipe from the "triangle" resonator/muffler, over the rear axle, to a Dynomax Super Turbo with 3" inlet/outlet and 3" turndown tip to conceal my business. I can report that at idle the car has a very very VERY deep sound, courtesy of the 3" piping, and has that very distinctive 5-cylinder sound. I've seen a few surprised looks already at stoplights, presumably from the race-car noises emanating from a Beetle. At partial throttle, Nubz sounds downright mean. Wide Open throttle, Nubz sounds like a UR Quattro (Click Here) but much smoother. Sounds like this but deeper (Click Here). There is no raspiness of any kind anywhere in the rev range. I do feel I've lost a little bit of torque just-off idle, but I would wager that I've gained many more above 3k rpm. Nubz' tachometer now sweeps much faster than before, almost like I installed a racing flywheel, and hits redline before you can blink! Overall I'm very pleased with the results. My only problem is the same thing that all aftermarket exhausts deal-with... drone at freeway cruising speeds! It is actually relatively tame and isn't all that bad - it doesn't rattle your teeth/coins, and you can still carry on a conversation. But it really bothers my sense of perfection, so I will continue to tinker and search for solutions. 55mph you can barely hear it. Just enough that you know it's there. 60mph (2k rpm) it's fine. 70mph (~2250rpm) is when it's getting close to peak. The resonance peaks somewhere around 75mph in 6th gear. The resonance almost goes away completely by 80mph. I suspect if I continue accelerating the exhaust noise would go away completely since I'm running a baffle-less exhaust at this point. I'm doing my first mpg tests this week, so no crazy-throttle applications... ![]() .addicted2sp33d (Judee's Chauffer) |
Blue One! |
Reliable (I think) MPG results are-in and it looks like I've gained about ~1.5 mpg, roughly a 5% improvement.
Same commute path, with consistent results over several tanks. I've done my best to eliminate driving-style from the equation by driving the same way I always drive. I would have been happy if the fuel mileage stayed the same since everyone that I've talked-to and everything that I've read expected a fuel economy drop. So I thought this is noteworthy enough to share! .addicted2sp33d (Judee's Chauffeur) |
It should. It's essentially VW's stock aftermarket exhaust. I believe it will work, it just may need a little bit of work. I haven't tried it yet, but one Dealership told me that's the exhaust they put on someone else's 2010 NB when they wanted a few upgrades.
I recorded a clip tonight but when I reviewed the video, I might have placed the camera a little too close. The camera was about 5' away and still got sprayed in condensation and the sound quality wasn't that good... I'll try again with a tripod tomorrow.
But here's the video anyway: ![]() Last edited by Judee; 06-29-2011 at 05:01 AM.. |
| 2.5" v. 3" Turbo Back Exhaust | jc918t | 1.8 Liter Turbo | 26 | 08-21-2010 06:37 PM |
| Tr: 42 Draft Designs 3" TB Exhaust for stock Beetle Turbo S Exhaust (Chicago) | r0nd3L | Parts and Accessories | 2 | 12-12-2008 11:10 PM |
| Exhaust Q: 2" pipes to 2 1/2" muffler? | Darkstar | Technical Modifications | 2 | 03-06-2007 02:50 PM |
| "exhaust malfunction" light?? | cassie | 1.9 Liter TDI | 3 | 07-22-2006 08:36 PM |
| checked out the "exhaust malfunction" light today.. | cassie | 1.9 Liter TDI | 4 | 07-18-2006 05:37 AM |
