Coolant light - NewBeetle.org Forums
Old 10-04-2010, 11:09 AM
ricaroo's Avatar
Rick
NH, USA
Car: 2007 NB Convertable triple Beige
Default Coolant light
I was under the hood checking out the coolant level, oil etc. Everything looks good. However when I started the car the coolant light came on and continued to flash while the car was running. I shut the car off and started it again and the coolant light went out like it always has. Whats up with that?
The only thing I did when I checked the coolant was take the cap off look in the tank and put the cap back on.
Any ideas whats going on? Is this normal? It doesn't happen every time
Thanks
Rick
Everything works out in the end, if it hasn't worked out,then it's not the end.
Old 10-04-2010, 11:27 AM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Thanks
Rick
Is it flashing red or blue?
Flashing red Red (upon a cold startup) usually means you are low on coolant and need to refill ASAP. Do not mix coolants.... If pink coolant is used, use vw's pink G12 coolant. If it is green, feel free to add more green, but look into getting all pink coolant soon!
Flashing Blue means its time for a new coolant temperature sensor. Those can be bought from your local autoparts store for $9.99 or at your local Vw Dealership for $27. Takes all of 5 minutes to change
Old 10-04-2010, 02:01 PM
ricaroo's Avatar
Rick
NH, USA
Hi,
It flashes red, I checked the level and it is not low
this flashing on cold start up only started after I took the cap off to check the condition inside the reservoir. The coolant level is right up to the mark on the reservoir.
Thanks
Old 10-04-2010, 02:03 PM
kellyyysayss's Avatar
Mount Holly, NJ, USA
Car: 2000 Beetle, 1964 Comet Caliente, 1966 Mustang
x2
When changing the temp sensor, have some G12/Coolant ready to put in, since a few inches may come out.
Old 10-04-2010, 02:32 PM
Fl_bug's Avatar
Miami, FL, USA
Hi,
Thanks
Thats low Does yours have the Max line?
Old 10-04-2010, 03:42 PM
ricaroo's Avatar
Rick
NH, USA
Yes it does have a max line,and no the coolant is not that high. It is on the min line when cold.
It seems odd that I never had a light come on until the day I took the cap off so I could see the condition of the coolant. I put the cap back on and now I get the light. I should have left well enough alone.
Rick
Old 10-04-2010, 04:00 PM
Fill it up closer to the max line, if not to it. The sensors are sensitive in these cars. If its at min, it will likely throw the light.
Old 10-04-2010, 07:31 PM
You can't have it at the min line, especially when it is cold, because it only drains further.
Don't fill it up to the max, either.
Fill it at the halfway point between the min and max lines, or just under the max line.
(This usually happens, not something to worry about!)
Old 10-05-2010, 09:11 AM
ricaroo's Avatar
Rick
NH, USA
I stopped by the VW dealer on the way home and picked up a gallon of G12 ($22) I put about 3 oz in started the car and NO light.
Thanks everyone for the help.
Rick
Old 10-05-2010, 02:16 PM
Rick
You have to make a 50-50 mix of DISTILLED water and G12.
What you did prob won't hurt you, but just so you know for another time.
Old 10-05-2010, 02:42 PM
Just means that next time you top up, use water instead of coolant. An exact 50/50 mix isn't necessary. I think 30/70 is even recommended in some cases.
Old 10-05-2010, 11:04 PM
Fl_bug's Avatar
Miami, FL, USA
The Gallon of G12 that the Vw Dealerships sells is premixed at 50/50
Old 10-06-2010, 12:08 AM
Not at my VW. Says clearly to mix 50-50 OR 70-30 (depending on the climate).
x2 to Smile on the water.
Blue coolant light comes on? ChuckDubDub 1.9 Liter TDI 22 05-17-2012 03:16 AM
Coolant? Blue Light? Karaokerobot Questions, Issues, Concerns, or Problems with the New Beetle 7 07-21-2010 09:43 AM
Coolant Light.. help! sazzleburger Questions, Issues, Concerns, or Problems with the New Beetle 1 07-26-2008 06:45 PM
Coolant light mbetti Questions, Issues, Concerns, or Problems with the New Beetle 3 06-12-2008 11:04 PM
Coolant Light... digitalputty 1.8 Liter Turbo 2 12-17-2006 12:22 AM
