Battery/Scan Tool basics - NewBeetle.org Forums
Old 10-24-2010, 10:33 PM
Wichita, KS, USA
Car: '06 2.5L (w/guitar)
Default Battery/Scan Tool basics
Hello - We are relatively new NB owners (2 yrs) and are changing out first battery. Our wonderful 2006 2.5L was just in for a few last pick ups since the warranty is running out, and they said the battery needed replacing. I have been doing the regular maintenance for the last 20K miles and use the bible (Bentley).
It has me shopping around for scan tools (since the few problems we've had have been linked to the ECM) but, after some searches on this forum I am now thinking I do not necessarily need to get a scan tool just for a battery change.
Any basic edification would be greatly appreciated and sorry if this is a stale, obvious question. I will hang up now and listen to your responses.
Cheers!
Old 10-28-2010, 03:03 PM
Knoxville, TN,
You will not need a scan tool to replace the battery. Once the battery is replaced, reset the clock, unlock the radio and relearn the one touch window function.
Clock resetting - if it has to be explained, one shouldn't be driving a car in the first place.
Unlock the radio - turn ignition on but don't start engine. Turn on radio, it is starts playing, done. If it says "safe" then "1000", pull key out of ignition. Put key right back into ignition and turn ignition on, do not start engine. Radio should unlock with that. If not, hope you got the radio code. See owner's manual.
One Touch Windows - with engine running, roll windows all the way up. Then pull up on the window switches and hold for 1 second, release, pull up for 1 second, release, pull up for 1 second, release. One touch up and down should now work.
Make sure you have the key out of the ignition prior to doing the battery swap.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 02-24-2011, 05:03 AM
woody95124's Avatar
volks r cool
san jose , CA,
Car: 2008 vert beetle
Default reset
On the window reset...D o u do all at once or one at a time???/I just bought a 2008 beetle vert and sometimes at night when headlights r on I go to pull down drivers window and all of the windows go up or down depending on what way I go on drivers window switch.Is this normal??headlights dim quite a bit probally because all windows r operating....seems wrong...thnx for feedback
Old 12-20-2011, 11:13 PM
woody95124's Avatar
volks r cool
san jose , CA,
Default battery /scan tool
I bought a cig light adapter with a 9 volt battery to use when I change my car battery to keep things ok when doing this ...Is this an ok thing to do??/or no???
Old 12-20-2011, 11:41 PM
MyOtherRidesAVette's Avatar
I have read of several Orgers doing this. Really not much different than using the solarcharger that was in the NB when it was shipped from Mexico.
More on...
Changing the Battery. Gimme your thoughts!
M.
scan tool wolfgangfurburr 2.0 Liter Gas 10 08-28-2010 09:50 AM
Can trouble codes be read without a scan tool? caldercay Questions, Issues, Concerns, or Problems with the New Beetle 5 01-06-2010 07:39 PM
OBD2 USB Scan tool Alton1968 Questions, Issues, Concerns, or Problems with the New Beetle 8 05-31-2007 09:23 PM
Scan tool for NB that works on other CAN bus cars? iFixBethsBug 2.0 Liter Gas 3 06-05-2006 07:35 PM
FS: scan tool, 2000GRT Market Place Archives 4 10-29-2005 03:05 AM
