Driver's side headlight - NewBeetle.org Forums
Old 12-01-2010, 01:45 PM
Default Driver's side headlight
Does anyone have photos for the removal of the driver's side headlight in a 2008 or newer Beetle. All of the posts that I find are either older models or the photos and/or threads are gone.
Thanks a million.
Old 12-08-2010, 10:40 PM
Stl5152733's Avatar
Julz bug
Springfield, MO, USA
Car: 2006 Bettle
How-To: 2006+ Headlight Removal
2006 Salsa Red
XM Radio
Alpine amps
Rockford Fosgate Subs
Old 12-10-2010, 06:43 PM
pvpeacock's Avatar
Palos Verdes Estates, CA, USA
Car: 2006 Convertible
The process is the same as that shown in the technical thread, however, it is much harder to see both the locking/unlocking nut and even harder to see the latch you need to push down on once it's unlocked. The latch is between the battery and air filter. When I did this two weeks ago, it helped to take off the battery cover and shine a flashlight down between the battery and air filter. Once you know where the latch is, it's pretty easy to spot since it is silver colored. Good luck.
Ka Pu'u
Driver's Side Headlight kellyyysayss Questions, Issues, Concerns, or Problems with the New Beetle 10 11-11-2010 03:07 PM
Driver's side brake light not working...other side is fine adamhiggins 1.8 Liter Turbo 8 06-16-2010 07:32 PM
HELP! Driver's side seat.... Dottie Beetle Questions, Issues, Concerns, or Problems with the New Beetle 5 10-24-2009 02:56 AM
WTB: '06 or Newer Driver's [LEFT] Side Headlight Cluster dieseldriver New Beetle Classifieds 0 02-08-2009 09:12 PM
Help lights out on driver's side Bean68 New Member Forum 1 06-02-2008 11:50 PM
