left side of the cylinder head
On a 2006, do you know if I can use the Green CTS as a replacement? My moms car has been starting in the morning (happens on real cold mornings) and after 10-15 seconds after noticing the idle doesn't really go into a warm up mode, the blue coolant temp indicator starts flashing red... I'll cycle the car on/off and it'll remain blue until warm and operate as normal.
Have you checked your coolant level?
Yeah, I just have a line that says minimum and then about an inch of gray lines above it but doesn't say "max". My coolant level is in that gray range, so I assumed that was OK?
| Coolant temp indicator/coolant temp sensor | terror_storm | 1.8 Liter Turbo | 2 | 11-07-2010 04:05 AM |
| Where is the coolant temp. sensor | jstargell34 | 2.0 Liter Gas | 9 | 03-29-2010 02:09 PM |
| Coolant Temp Sensor | cfree3 | 1.9 Liter TDI | 2 | 03-05-2010 08:03 PM |
| Coolant Temp Sensor | Diognes56 | 2.0 Liter Gas | 11 | 08-07-2007 03:43 PM |
| Where is the coolant temp sensor? | DruzeTito | 1.8 Liter Turbo | 8 | 06-22-2006 02:35 AM |
