turn signal sound generator problems - NewBeetle.org Forums
Old 05-28-2011, 07:53 PM
CO,
Car: 2002 2.0L manual GLS
Default turn signal sound generator problems
Hello everyone,
I have a 2002 2.0L normally aspirated beetle and the turn signal is having an intermittent problem that I hope you can help me diagnose.
When I use the turn signal the turn signals work, the dashboard indicator works and the clicking noise starts. The problem is that when I switch the turn signal off the ticking sound often keeps ticking. Sometimes the sound comes on and stays on randomly (without even using the turn signal).
If it's possible I would be willing to just disarm the noise generator. Any advice that you have would be great.
Old 05-29-2011, 03:42 AM
digitalputty's Avatar
Where is home ....
Lone Tree, Greeley, USA
Car: 2003.5 GLS BLCC (Zoomer)
I have the same problem right now. So, if any one has ideas ... that would be awesome. Right now I am thinking it is the turn signal lever ... or, the hazard light button. ??
Old 06-01-2011, 04:50 AM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
Both of you check my signature for the diy for this...
Old 06-01-2011, 03:03 PM
AFAIK the sound for the turn signals actually comes from a relay so no getting rid of it.
The hazard switch is likely your culprit, as Lnzbug has in her sig.
Old 06-02-2011, 04:51 PM
CO,
Thanks guys
ANOTHER Turn Signal Blink Gone Bad..?!? WTH?!? spinjector 1.8 Liter Turbo 21 08-04-2010 08:12 PM
P/s turn signal etsmarch05 1.8 Liter Turbo 0 07-01-2009 05:57 PM
Air Pump and Turn Signal Problems flightmedic02 1.8 Liter Turbo 7 10-12-2008 09:38 PM
Turn signal 4toyhln 1.9 Liter TDI 2 10-04-2008 04:53 PM
Lame turn signal sound after replacing Hazard Switch helga Questions, Issues, Concerns, or Problems with the New Beetle 4 10-06-2006 09:01 PM
