belt routing - NewBeetle.org Forums
Old 06-29-2011, 02:43 PM
Default belt routing
looking for a diagram for the belt routing on 2006 2.5 beetle?
Old 06-29-2011, 02:44 PM
Blugg's Avatar
Alaska, United Kingdom
Car: 1.9 TDi Alaskan Green
2 secs
Old 06-29-2011, 02:45 PM
Blugg's Avatar
Here
2006 New Beetle VW Replacement Parts
Old 06-29-2011, 02:48 PM
That site basically just takes images from ETKA. Not sure how its really even still online to be honest. Also terribly organized.
Old 06-29-2011, 03:12 PM
Blugg's Avatar
There is a diagram of the belts ?
Surely that is of some help
More than just a moan reply
Old 06-29-2011, 04:26 PM
Well, the 2.5 has a timing chain, and should only have a serp belt. The problem is, that site shows all engines, and can easily confuse. My Bentley only goes through 2002, otherwise I'd look up and scan the diagram from it.
Old 06-29-2011, 05:42 PM
Blugg's Avatar
Thankyou for explaining that
R&R 2.0 AZG and need input on vacumn routing and coolant expansion bboldt3 Engine Swaps 1 03-26-2009 01:52 AM
Routing of CD Changer wiring? FarrisK Car Audio 4 12-26-2008 05:27 AM
Vacuum routing pic needed NBTurboFreak 1.8 Liter Turbo 7 06-30-2008 04:02 AM
Egr/valve thingy Vacuum line routing Ghostride 2.0 Liter Gas 4 04-14-2008 01:34 AM
Routing Amp power cable Troubles Crazy_MoFo Car Audio 12 12-22-2005 09:37 AM
