2006 Beetle 2.5 L P0322 - Engine Speed Sensor (Crank Sensor) (G28): No Signal - NewBeetle.org Forums
Old 07-27-2011, 12:37 PM
Default 2006 Beetle 2.5 L P0322 - Engine Speed Sensor (Crank Sensor) (G28): No Signal
Hi All,
Just wanted to put this up in case is anyone else might need it.
Ive been looking for something regarding this job, but no luck.
Purchased a ACTRON (9575) code scanner to see what was going on.
The EPC was lit up as well as the check engine lite.
2006 VW, New Beetle, 2.5 L, Convertible
Code P0322 was coming up with the occasional MAP code (forgot the number).
Symptoms:
* Engine shuts off while driving
* Engine doesn't start back right away
* Speedometer/Tach inoperative
I had a hard time finding the sensor. Couldn’t really find good details…
But after some searching I found it!
Basically I had to lower the skid plate.
I couldn’t remove it since I didn’t have 12 pt torx
But, I could lower it enough to get to the hole that the sensor is bolted in.
Removed the 2 bolts with a T-handle allen wrench. I think it was a 5mm.
Sensor came right out. Not tight at all. Just fell out.
Replaced with the new one, and it was a success! Codes cleared, drove about 20 miles. No problems!
Hope this helps. Let me know if I have any mistakes on here… I’m no pro…
Old 04-18-2012, 11:47 AM
FT. WAYNE, IN,
Car: 09 Beetle
This is a really good DIY, if the dealer wants to replace it, tell them you will do it and just buy the part, Home Page > Search > Sensor > ES#274800 SENSOR - 037905377B
And its a 4mm Allen head.
it takes about 20 mins to do.
08 Rabbit S
09 New Beetle
Tags
2006 beetle 2.5 l , crank sensor , engine speed sensor , g28 , p0322
Engine Speed Sensor connieray 1.8 Liter Turbo 3 07-06-2011 11:46 PM
engine speed sensor pepino68 1.8 Liter Turbo 0 12-11-2010 01:01 AM
engine speed sensor the dozerman 2.0 Liter Gas 0 10-26-2010 08:31 PM
Engine Speed Sensor..... OldSkoolVWLover Technical Modifications 0 01-20-2009 12:23 AM
pls help: G28 Engine Speed Sensor: no signal ninsei 1.8 Liter Turbo 1 01-09-2006 05:09 PM
