ECS Tuning Fog Light Kit - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 11-25-2011, 02:22 PM
MyOtherRidesAVette's Avatar
It appears, from all I can find, that front fogs were optional, only as an inclusion, in the Package 2 Option on the 2006 and 2007 models. I can find no reference to front fogs being avaiilable singularly or as part of any package after 2007.
Based on this, I would have to say, the kit is P&P for the 2006 and 2007. For models after 2007, you have your work cut out, as Duffy did. Maybe someone can update this if you have factory front fogs in your 2008, 2009, or 2010.
M.
  #22 (permalink)
Old 11-30-2011, 06:15 AM
patsajak's Avatar
mines an 07, but duffys post made me more lost
  #23 (permalink)
Old 11-30-2011, 10:21 AM
Fogs were not available AFTER the 2007 model year.Having been available on the 2007 model as a Package 2 option, the wiring SHOULD be in place in yours. As with any production change, things can change as the plant's inventory is depleted. VW Parts Dept may be able to confirm that yours has the correct wiring harness to receive the fogs, by your VIN. As said, if you can visually confirm that the fog plug(s) are in place in your headlight harness it is a pretty good assumption you will be able to plug and play the kit. The relay will have to be plugged in. Since the fog option was long gone by '09 (Duffy's), he had to work from scratch. Forget the "relay, don't know why" comment. The relay is needed in the circuit if your NB has the fog wiring in place.
Does this help?
M.
  #24 (permalink)
Old 11-30-2011, 11:28 AM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
M.
Aw! the reason for the relay. So, if the car is "fog ready" then all is needed is the fog lights and grilles. Hummm, do you suppose the fog inhibit relay is already installed too? What about the fog pull out position on the light switch? If not, by all means install the Euro light switch.
Sorry to have confused anyone.
Tom
  #25 (permalink)
Old 11-30-2011, 11:43 AM
It would be very unlikey the inhibit relay would be installed already, without the option on the car, no reason for the factory to spend the money. Good point about the switch! I have no clue, if prior to the total elimination of the fog option, VW used two different switches, or if one switch was used, with the switches in all vehicles being "fog ready". Again because of the pending deletion of the option, it's possible if the wiring is there that the switch is not. Logic, however, has it that if the same switch WAS used, regardless, the factory would have had on hand approximately the same number of switches as harnesses, e.g. oreder 10k of one from the vendor, order 10k of the other. The OPer can check this easy enough by testing to see if his existing switch has the feature, even though it would, in his vehicle, do nothing.
M.
  #26 (permalink)
Old 11-30-2011, 11:53 AM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
MORAV, this should clear up everything nicely.
  #27 (permalink)
Old 11-30-2011, 11:57 AM
Maybe Duff, maybe! Thanks for the thought on the switch, I never even considered that. Hope the OPer can do the mod! Any idea where, in the headlight harness, to tell him to look for the fog light plug? Is there just one or two (the wiring diagram doesn't really reveal).
  #28 (permalink)
Old 01-01-2012, 05:57 PM
patsajak's Avatar
Does this help?
M.
where would the head light harness be, and where would the plug on it be?
Installation of ECS Tuning Fog Light Conversion Kit johnb Technical Modifications 1 07-09-2011 11:33 PM
ECS Tuning FallinApartBoy Feedback Forum 13 02-27-2010 03:47 PM
ECS Tuning bluebee Market Place Archives 9 03-27-2007 01:41 AM
Speed Tuning USA ECU tuning? cyberbeetle Technical Modifications 1 06-21-2006 05:32 PM
ECS Tuning! FineExampl Market Place Archives 11 06-08-2006 05:40 AM
