Headlights - No Low Beams - NewBeetle.org Forums
Old 01-07-2012, 09:03 PM
Default Headlights - No Low Beams
2006 Beetle 2.5L
Low Beams do not work, high beams do. Here is what I have tried:
- Replaced bulbs (same no low beams)
- Check and swapped fuses with high beams (same no low beams)
I have read there maybe a relay but not sure how to get the lower dash off or if there is a relay for the low beams on this year.
Thanks for any ideas...
Old 01-11-2012, 11:37 PM
Not to be funny but are u sure they locked fully and pushed in all the way. I've been having problems with my low bean I was even thinking on cutting the connector bracket so I could physically push in it. But I just took a pry bar and pushed the connector in: havent had any problem so far
Old 01-11-2012, 11:45 PM
Yes they are pushed in all of the way. The high beams and running lights work just fine.
Is there a relay for the low beams?
Old 01-12-2012, 03:10 AM
IndyTom's Avatar
Indianapolis, IN, USA
Take out your headlight switch and check to see if the connector or the wire for the low beams is loose.
Old 01-12-2012, 11:29 PM
Would it be a switch issue with the running lights come on and the high beams work?
How do you get the switch out?
Is there a relay related to the low beams.
Old 01-13-2012, 02:53 AM
IndyTom's Avatar
The daylight running lights are connected to a different wire so it is possible that your DRL's work just fine but your Low beams don't.
What year beetle do you have?
The later models had a much smaller headlight switch connector than the older models. Either way to get the headlight switch out PUSH in the knob then turn it inbetween the off and the next setting, then it pulls right out.
This thread might help:
need help removing headlight switch on 2001 newbeetle
Here is even a You tube video:
http://www.youtube.com/watch?v=5v-RKI5X5Zw
Another thing I can think of is the Handbrake switch. When pulled it turns off the headlights. Perhaps it is faulty?
The DRL Relay is 173. I am not 100% sure but I don't think there is a Low Beam Relay. But I could be wrong.
Did you check the fuses?
Old 01-14-2012, 12:58 AM
Yes I checked the fuses, and even swapped them out with the high beams to test them. Its a 2006...
Where is the DRL Relay?
Old 01-14-2012, 03:19 PM
IndyTom's Avatar
The Relay's are underneath the lower dash. You may have to remove the cover beneath the steering wheel to get to them. But you have a 2006 and I am not even sure if you still have the 173 DRL relay. They changed a lot of things in 2006. Besides the DRL relay will not have anything to do with your Low Beams.
Old 01-14-2012, 03:31 PM
I was confused when looking for relay information as I could not find a lot of information on them for 2006.
So how do I get to the ignition switch? My luck removing the lower dash has not been great so far but I'm not sure it needs removed to get to the ignition switch.
Old 01-14-2012, 03:43 PM
IndyTom's Avatar
I looked everywhere for a Headlight Relay but there isn't one mentioned anywhere. I have the Haynes VW Repair Manual and it never once mentions a Headlight Relay for Low or High Beams.
I would investigate your switch and do a test with a multimeter on it. I bet if you swapped out both bulbs and they still don't work it must have something to do with the headlight switch.
Old 01-14-2012, 03:45 PM
IndyTom's Avatar
Why do you want to get to the ignition switch?
Old 01-14-2012, 05:37 PM
Read a few places that it can be related. Going to check the switch first but that's next on the list.
08 conv low beams keep burning out! 008bug New Beetle Convertible 3 12-19-2011 05:51 PM
High beams blue idicator stuck on but low beams shining? Zann Questions, Issues, Concerns, or Problems with the New Beetle 9 11-17-2011 08:26 PM
Fog lights with high-beams Bo185 Technical Modifications 11 08-06-2009 10:20 PM
04 low beams suck! JEGSSR Technical Modifications 4 07-20-2009 02:40 AM
FS: pair of beetle headlights with hyperwhite high beams and low beams dragonplayboy Market Place Archives 7 06-02-2006 02:30 PM
