Coolant Temperature Warning Light - NewBeetle.org Forums
Old 01-24-2012, 02:36 AM
RBHRegistered Member RBH is offline
Default Coolant Temperature Warning Light
We have a '09 Convertible Beetle.
The coolant temperature sensor warning light is BLUE when the engine is cold and then turns off as the engine warms up.
That is until two months ago, the warning light would go off and then indicate BLUE again after the vehicle had been driven for more than 10 minutes.
Took vehicle in for service. They indicated coolant level was somewhat low but the system was not leaking. Now the warning light is never BLUE even when the engine is cold.
Took vehicle back for repair and was told that '09 does not have this feature - coolant temperature warning light should never be BLUE.
We replaced coolant temperature sensor which was a 4-pin just like our '98 Hardtop Beetle.
The warning light still never turns BLUE.
Bottom line is the warning light in '09 worked just like the warning light in '98 - BLUE = cold and RED = hot but now warning light in '09 is never BLUE.
Does this scenario indicate that we may have a computer problem?
We have had a few other strange things happen - radio suddenly shuts off while driving, random warning lights indicate when there is no problem, and windows roll down when door is opened but then they do not close when door is closed, etc.
Thanks!
Old 02-26-2012, 12:56 AM
turbokid's Avatar
Middle Tennessee
Pleasant View, TN, USA
Car: 2006 Aquarius Blue Vert
I have a 2006 Vert and it will indeed turn blue. If the coolant level is correct, then it's ok. It will disappear when it reaches operating temp. It would only do that when it was really cold outside. It's in your manual, at least it's in ours, and ours is a 2006. It's really not a warning, It's kinda saying, let the engine warm up a few minutes.
Thanks!
-Life is too short.. Eat your dessert first
solid blue engine coolant temperature light soccer_hooligan 2.0 Liter Gas 4 04-22-2011 01:34 AM
Coolant Temperature Sensor....gone bad? orangeshrimp72 1.8 Liter Turbo 9 09-29-2010 01:04 AM
Blue Coolant Warning Light kalooki 2.0 Liter Gas 26 11-14-2008 08:20 PM
which coolant temperature sensor? strorg 2.0 Liter Gas 4 10-31-2007 11:02 AM
Temp light warning - but coolant looks ok? Burke 2.0 Liter Gas 18 10-18-2007 10:48 PM
