You got the right stuff. Keep in mind that channel locks CAN take the top off the oil canister to put the filter in, but it's totally plastic and it can misthread easily and break. This is bad cause a lose/broken oil filter cap = lost oil and oil pressure = low oil light = seized engine.
There is a tool that VW sells to undo it; my personal mechanic said taking your time with channel locks is the only way to do it right now since the part is back ordered... he said dealers in my area were advised to stock up on caps, if the old one broke while changing the filter element, put ion a new cap (but didn't say to or not to charge cap cost to the customer... knowing their practices it'll be a $110 oil change).
If it's the same cap as a TDI filter, you can use a normap end-style cap that attaches to a ratchet to loosen the filter cover.
-Des |
Your local hardware store stocks the tool to remove the filter caps. I can't remember the size, but count the "sides" of the filter cap (14 I think) and its a smaller diameter 76 mm?. I just asked if I could take a few out to my car to check to make sure it fit correctly. I'll check to see which size it is.
$ 2.99 is what I paid. |
You will need to drain the filter housing PRIOR to removing the filter. If not, you will have oil everywhere - a real mess. Use tool T40057 (ebay or ECS Tuning) as a source. I use Mobil1 0w40 in my 09NBC and VW filters
DIY: Oil Change for 2.5L
Tom I haven't seen an adult since I was a kid!
I use one of these (Click Here)
![]() It's basically universal fit, and doesn't care if the filter doesn't have those squared-off sections, or if it's one of those new "grippy" cannisters. Best of all, it doesn't care about the filter height/length. The filter housing could be 2 feet long and it would still work. .addicted2sp33d (Judee's Chauffeur) |
| How to replace the Pollen Filter | heeeheee | 1.8 Liter Turbo | 5 | 12-28-2009 03:06 PM |
| Fuel Filter | iScott | 2.0 Liter Gas | 4 | 04-26-2006 02:25 PM |
| Oil Filter Cost | BobTdi | 1.9 Liter TDI | 12 | 04-25-2006 12:55 PM |
| Air Filter | black_bug | 1.8 Liter Turbo | 3 | 02-20-2006 05:59 AM |
| Which Oil Filter to use on a 1.8 | slugo | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 10-18-2005 01:14 AM |
