Easy to do, but you'll create a problem, in that they are designed to only run as needed, and this includes AFTER you have turned off the ignition and the engine has heated to a temp hotter than when you shut it down. They will typically run for up to 10 min after engine is turned off. And what about winter, when you want the coolant temp higher.? This will probably also interfere with all the things that are designed to operate at a certain temp. Old school, we always took the thermostat out for cooler running, you wouldn't dare do that today. As a matter of fact, I could trick out the cooling on a big block and not get the temp guage up off the peg! No heat in the winter, but damn my engine ran long, cool, and forever. Remember, OLD SCHOOL.
But as I always suggest to anyone with more knowledge than the engineer(s) that design something, go for it. I can look at the wiring schematic in the Bentley and tell you how to do it if you'd like!
M.
In der Automobil-Scheune
